Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
I believe that plot is for cerbera (the other simon), not quite as full on as the original.
Agree T04GTR, my 35r is far from boring (esp rwd) but it doesnt compare to the nothing nothing bang and scream to the limiter of a mates hks t04z - but he is cheating with a jun stroker :P he also has awd so its not a very fair comparison I spose.
Ahh fair enough :)
My GT35R should be on in a month or so and I will post the tyre frying results :(
Agree T04GTR, my 35r is far from boring (esp rwd) but it doesnt compare to the nothing nothing bang and scream to the limiter of a mates hks t04z - but he is cheating with a jun stroker :down: he also has awd so its not a very fair comparison I spose.
come on i was carrying an extra 400kg than you too so i think the stroker is fair :P Pity u never took me for a spin to compare it though, looks like i'll have to wait a while
Simon aka R32-GTS is who DCIEVE is talking about (I think :)). Too much headwork to compare to any old 26 with a T04Z
It's Cerberas graph.
I used that one instead of Natallottos because Cerbera has no head porting, and just mild 270 degree cams.
The 35R has been scaled 5% to take into account its on a hubber.
It's the closest thing I could get to a fair comparisson between the two, and subsequently, I've just purchased a 35R.
hey how did yours come up michael? obviously happy with the results!
here is a link to our car running a HKS TO4Z setup at the Bathurst sprint a few weeks ago, overall the results we pretty good but takes abit to get use to as we are use to running small twin setups.
we limited boost to 25psi which made approx 430 awkw's on the rollers, fiddled with cams a fair bit whiched helped the middle alot, i think full boost was around 4700 - 4800.
http://au.youtube.com/watch?v=lf6opg6Mdt0
cheers russ
p.s i prefer more response, but the single rush was good too. wouldnt be as much fun on a tight track
Spoolup has a to4z on his rb30det.
There's a few dyno sheets on the link below.
http://www.spoolimports.com/content/SpoolImportsR33.asp
R34 NEO head - HKS 272 / 9.35 cams, Performance Valve Springs
Garrett T04Z turbo 0.96 ex housing
23psi 581rwhp.
The boosts knee so to speak appears to be a little after 4000rpm.
A pair of 272 10.5mm lift cams would work much better on his setup.
As for a GT35 pushing more than a genuine 400rwkw (535rwhp) on the RB with pump fuel. I'm not a believer. :)
Edited by TheRogue
As for a GT35 pushing more than a genuine 400rwkw (535rwhp) on the RB with pump fuel. I'm not a believer. :D
Thats unfortunate, it has been done time and time again and all going well I'll hopefully be able to post a plot for another one in a month.
From the horses mouth :D
My 35R is so close to being on I can feel the happiness in my pants stirring :D
cheers russ
Hey Russ,
yep we are only running 20psi at the moment, 330kw, fair way short of the big T04Z. havent touched the cams. full boost around 4300rpm. Will get to QR at the first Timeattack and see how it goes.
I'm thinking down the track try some fuel and 26psi. :D
Maybe for superlap!! :D
Sounds almost like he'd have been happier with a GT35R :D I'm pretty sure that power would be achieveable with 25psi on race gas, and in my experience a GT35R feels a bit more lively underfoot than a pair of GT2860-5s.
yeah, I'm thinking 26psi and some good fuel, I should touch up 400kw on the 2.6 35R combo. will look at that hopefully for superlap! :D
Between the gears, down low it's just awesome. Can't wait to put more boost into it, I'm sure it will come alive.
defo, would be great
post the link! :)
not that we want to go too off topic, but heres my on-car footage.
http://au.youtube.com/watch?v=g8aiGRO5Ifk
yeah, i just think the 35 is boring compared to t04z, besides hks doesnt do a gt35 equivalent.... lagmaster ftw. :)
Correct. The closest thing that HKS have to a GT35R is the GT3240 (rated by HKS at 580hp), which is a GT35R with a cut-back rear wheel and 0.87 housing ;)
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
