Duncan1 Posted January 13, 2010 Share Posted January 13, 2010 my t04z is a split pulse t4 flange - same as the GT3788. The 4088R is a bigger turbo than the T04Z (compressor and turbine) so it will flow more HP, with a tiny bit more lag.Main reason for doing the swap is simply that the Z is too doughy out of medium tight corners around the track. IE: turns 3/4 @ QR I take at about 80km/hr. 2nd gear == massive tailslide on exit, whilst 3rd gear == LAG all the way out of the corner. Hopefully the new turbo is not only slightly more responsive, but a lot more linear in power delivery. I make 1 bar at 4100rpm with the Z and 24psi at 4500. Thats not too laggy, but as soon as you go below 4000 rpm there is absolutely nothing there. I wouldnt care too much if the 3788 only makes 1 bar at 4000rpm as long as 3800/3900 still had SOMETHING available unlike the Z which comes on like a lightswitch once you get over 4. The only unfortuante thing is that I wont be able to directly compare how the 2 turbo's would have worked on the track as I'm making some other significant changes to the car at the same time. So wont be able to say if the 3788 is soley responsible for better lap times, but hopefully combined with everything else we are doing it makes a big difference. Still probably a couple of weeks away from doing the swap - will see how we go. What else are you doing mate!?!?!!?!?!? Is it going to be ready for the 11th? We are going to run high boost on the T04z this time and see what we can times we can squeeze out of it. Hopefully the new balancer will keep all the belts on the car unlike last times sad effort! Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5031925 Share on other sites More sharing options...
Duncan1 Posted January 13, 2010 Share Posted January 13, 2010 #### Couldnt edit my first abortion of a sentence.this should make more sense What else are you doing mate!?!?!!?!?!? Is it going to be ready for the 11th? We are going to run high boost on the T04z this time and see what times we can squeeze out of it. Hopefully the new balancer will keep all the belts on the car unlike last times sad effort! Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5032048 Share on other sites More sharing options...
Strik3r Posted January 13, 2010 Share Posted January 13, 2010 What else are you doing mate!?!?!!?!?!?Is it going to be ready for the 11th? We are going to run high boost on the T04z this time and see what we can times we can squeeze out of it. Hopefully the new balancer will keep all the belts on the car unlike last times sad effort! Oh few bits and pieces. Got some softer suspension going in as the 12kg springs that were on there were way to hard. The car will definitely be there on the 11th even if i have to push the damn thing around the track hopefully catcha then ! Look forward to seeing what you can do with the good ole Z Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5033103 Share on other sites More sharing options...
Duncan1 Posted January 13, 2010 Share Posted January 13, 2010 Oh few bits and pieces. Got some softer suspension going in as the 12kg springs that were on there were way to hard. The car will definitely be there on the 11th even if i have to push the damn thing around the track hopefully catcha then ! Look forward to seeing what you can do with the good ole Z Nice mate, Looking forward to seeing your new setup in action! Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5033587 Share on other sites More sharing options...
Lithium Posted January 14, 2010 Share Posted January 14, 2010 The 4088R is a bigger turbo than the T04Z (compressor and turbine) so it will flow more HP, with a tiny bit more lag.I make 1 bar at 4100rpm with the Z and 24psi at 4500. Thats not too laggy, but as soon as you go below 4000 rpm there is absolutely nothing there. I wouldnt care too much if the 3788 only makes 1 bar at 4000rpm as long as 3800/3900 still had SOMETHING available unlike the Z which comes on like a lightswitch once you get over 4. Wont be able to say if the 3788 is soley responsible for better lap times, but hopefully combined with everything else we are doing it makes a big difference. Are you running an RB30? 1bar at 4100rpm isn't that bad Strictly speaking the GT4088R isn't really a bigger turbo than the T04Z, the T04Z has a bigger compressor which wants to flow a bit more air - the Supra guys in the States and the UK seem to be increasingly moving from the T04Z to the GT4088R as the fun 700+ish turbo to have, the GT4088R is apparently more useable and generally fun. Look forward to hearing how the GT3788R treats you, I've never heard of one used on a petrol motor. Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5033797 Share on other sites More sharing options...
SimonR32 Posted January 14, 2010 Share Posted January 14, 2010 Are you running an RB30? 1bar at 4100rpm isn't that bad sounds like rb26 response.... in 4th gear on a flat road loading up the motor i was getting 1bar around 3700rpm on my stock capacity rb26 Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5033833 Share on other sites More sharing options...
Lithium Posted January 14, 2010 Share Posted January 14, 2010 ^ On a T04Z? Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5034003 Share on other sites More sharing options...
SimonR32 Posted January 14, 2010 Share Posted January 14, 2010 yeah Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5034078 Share on other sites More sharing options...
Butters Posted January 14, 2010 Share Posted January 14, 2010 Smoking Crack whilst driving helps Cerbera think the boost is coming on sooner. Also Cerbs .... 139mph last night with a GT35 !! ANDRA guy got angry and told me to get a chute ..... jeeeeeez never ends ! Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5034577 Share on other sites More sharing options...
NYTSKY Posted January 14, 2010 Share Posted January 14, 2010 139! Thats wicked Simon! Cant wait to get mine tuned Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5034581 Share on other sites More sharing options...
Brockas Posted January 14, 2010 Share Posted January 14, 2010 E85 FTW!! Nice work Simmo. Might have to smash some E85 into the GT-R and see if she does 650 Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5034597 Share on other sites More sharing options...
NYTSKY Posted January 14, 2010 Share Posted January 14, 2010 Doooo iiiiiit!! Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5034616 Share on other sites More sharing options...
N I B Posted January 14, 2010 Share Posted January 14, 2010 Good job, I guessed your weight at 2800lb?s and put your run in the Power calculator and it came up at 560hp so the numbers sound right. http://www.turbofast.com.au/Drag.html Reasonable guide but remember its engine power. Im surprised just how close this has been. Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5034623 Share on other sites More sharing options...
ahh 33 s2 Posted January 14, 2010 Share Posted January 14, 2010 (edited) dam id love to see a skyline run 139 at the plex, where are u getting ur E85 from in perth? silvia even Edited January 14, 2010 by ahh 33 s2 Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5034775 Share on other sites More sharing options...
N I B Posted January 14, 2010 Share Posted January 14, 2010 Filters Elite sell Race E85 mixed with 110 Race fuel and Racetorque sell E85 mixed with 98. Our Racecars are on the Race E85. Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5034917 Share on other sites More sharing options...
unique1 Posted January 14, 2010 Share Posted January 14, 2010 Filters Elite sell Race E85 mixed with 110 Race fuel and Racetorque sell E85 mixed with 98.Our Racecars are on the Race E85. how much are they per litre for each Steve? Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5035231 Share on other sites More sharing options...
Butters Posted January 14, 2010 Share Posted January 14, 2010 I've been getting E85 from RPW. They are selling the V8 supercar CSR control fuel. Brockas you will become a junky for the stuff once you try it !! Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5035361 Share on other sites More sharing options...
SimonR32 Posted January 14, 2010 Share Posted January 14, 2010 simmo what injector size and injector duty are you getting with 560rwhp? Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5035429 Share on other sites More sharing options...
Butters Posted January 14, 2010 Share Posted January 14, 2010 Running 1000cc injectors and low rail pressure. It gets to 90%. Not sure how the pump would fair on higher rail pressure but in theory a lot more injector available. Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5035439 Share on other sites More sharing options...
Strik3r Posted January 15, 2010 Share Posted January 15, 2010 Are you running an RB30? 1bar at 4100rpm isn't that bad Strictly speaking the GT4088R isn't really a bigger turbo than the T04Z, the T04Z has a bigger compressor which wants to flow a bit more air - the Supra guys in the States and the UK seem to be increasingly moving from the T04Z to the GT4088R as the fun 700+ish turbo to have, the GT4088R is apparently more useable and generally fun. Look forward to hearing how the GT3788R treats you, I've never heard of one used on a petrol motor. Yea, the compressors of the 2 turbo's are fairly similar in the scheme of things -> TO4Z Inducer 66.7mm Exducer 84.0mm Turbine: 74.2mm 4088R Inducer 63.5mm Exducer 88.0mm Turbine: 77.0mm Doesn't the exducer determine how much air it can flow ? People seem to be getting a bit more HP out of the 4088's than the Z's.. the fin design of the new garrett turbo's is more efficient than the older Z's. Link to comment https://www.sau.com.au/forums/topic/246293-gt35r-vs-garrett-t04z-discussion-just-post-in-this-thread-to-create-a-database/page/34/#findComment-5035945 Share on other sites More sharing options...
