Hey guys,
I contacted 6BOOST today and they are kind enough to offer a huge saving off there top quality Manifolds.
All Turbo Manifolds are designed around a unique "Merge collector". This type of collector technology has been used in the highest forms of motor sport for years, but never applied commercially to turbo manifolds anywhere in the world. The design of the merge collector is such that all gases are directed at the turbine entry; no pipes enter across each other, disrupting gas flow. The distinct look and design of the collector is easily recognisable, with the pipes entering in a circle and forming a "point" or "spire".
With this collector technology we have seen anywhere from 200-400RPM faster spool and gains in the region of 6-15% in power in back to back dyno testing, even on highly tuned race engines. Every single engine that has been back to back tested to date has made more power and spooled faster. All manifolds are constructed from thick wall mandrel bent steam pipe and are designed and built in Australia to be of the highest quality available. All manifolds are heavily sandblasted inside and out and coated in high temp exhaust enamel that has proven to stand the excessive heat of a turbocharged environment. They also come with studs and nuts for your cylinder head and turbo flanges are faced and hand ported ready to be used.
All 6boost manifolds come with a lifetime warranty against cracking and defects, an Australian first in turbo manifold manufacture.
Manifolds pricing is:
RB20/RB25 - $950
RB20/RB25 Split Pulse (faster spool up) - $1000
SR20 - Prices up soon
If you are interested in rb26, 1jz, xr6 turbo, etc... contact me via PM and i will double check pricing, but im pretty sure its the same.
Remember you can get High/Low Mount, Internal/External Gated manifolds, all the same price. We need 6 people, a $100 deposit will be taken befor the manifolds are made. If you require a different flange please specify so and it can be made to your choice. If we do not get 6 manifolds the price will be about $50 more. RRP is $1200. Manifolds will be purchased late December.
List:
  1. 1.Choku_dori - RB20/25 high external, sr20 high external - deposit taken
    2.Shilohr32gtr - rb26 single high mount - deposit taken
    3. wisey18 - R34 RB25DET Stock location, low mount, internal gate - waiting deposit
    4. Tamimego - (ns.com) low mount sr20det t28 internal gate - waiting deposit
    5. blockasR32 - RB26 Single High mount External gate - deposit taken
    6. bigadz - lowmount sr20det manifold standard flange for GT2871R internaly gated - deposit taken
Edited by 2rismo
https://www.sau.com.au/forums/topic/246661-6boost-steampipe-manifolds/
  • Replies 92
Yes sorry, i havent got a price for RB26 yet. If you are interested i will call them and organise something.
Okay, ill ring tomorow and get more specifics like, twin single high or low for the RB26's. Ill update it tomorow.
Anyone know how i can edit my first post... it wont let me :(
PM replied
1. Choku_dori (2 manifolds)
2. Shilohr32gtr
Deposits are made to...
National Australia Bank
Acc Name: Leon Minic
BSB: 084-792
Acc Number 79-164-3300
Edited by choku_dori
I may be interested in a High mount for sr20det with external gate, standard flange for gt2871r, what type of prices?
Whats delivery like? ie im in Perth
PS: update your first post with all the relevant details it saves reading all your posts
Edited by volt_bite
Not quite sure what you mean by a balancer pipe. But Twin low mounts are $1100. If you want twin high mounts let me know and i can have that arranged, but must be BEFOR monday.
If anyone can help me out in editing my first post would be very appreciated :unsure:
SR20DET High or low internal or external all $800!!!!!!!!!!!!!
List...
1.Choku_dori (2 manifolds) - deposit taken
4. Tamimego (ns.com) low mount sr20det t28 internal gate - waiting deposit
5. blockasR32 RB26 Single High mount External gate - deposit taken
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
