hi i got done a month ago for bald rear tyres in my 2 door witch wernt at all so all i done literly was drove down to christys cop shop an got it aken off the sapol officer came out checked them an said yep fine to me an explaind i should sell the car as its a target as theses cars get used all he time in high speed pursuits i then said to him have a look in he back see the child seat dont think so bloke
mechainc at work has a r32 got a canarie to regency 2 days after he got it passed i t got done again for the same things wich he changed so i said for him to take it to the cop shop an explain whats happend an the officer went out looked at the car asked if the exhaust was stock an then took the sticker off an cleared the car
ive also been told wether its a myth or not or if it works i dont try to get done but its go's along like this if you go to motor reg an give them the rego number an vin an ask if the car is defected as your lookin into buying it if its not then your car isnt as i said im not sure if it work or its a myth
Translated: :)
Hello. I got done a month ago for bald rear tyres in my 2 door, which were not at all. So all I did, literally, was drove down to Christies Beach Police Station an got the defect taken off. The SAPOL officer came out checked them and said "Yep, fine to me" and explained I should sell the car as its a target, as these cars get used all the time in high speed pursuits. I then said to him "Have a look in the back. See the child seat? Don't think so bloke".
Mechanic at work has an R32. Got a canary. Went to regency. 2 days after he got it passed, it got done again for the same things which he changed to clear the first defect. So I said for him to take it to the police station and explain whats happened. The officer went out looked at the car. The officer asked if the exhaust was stock, and then took the sticker off and cleared the car when he was satisified with its roadworthiness.
I've also been told, whether its a myth or not or if it works (I don't try to get done, but its goes along like this), if you go to motor reg and give them the registration number and vin, ask if the car is defected as your looking into buying it. If its not then your car isn't defected. As I said I am not sure if it work, or if its a myth.
Yes, I'm bored :)
Don't people do English at school anymore?
Hi
I have an a booking at Regencey to get SA reg on my car ( no Australian compliance plate )and I am not sure about the turbos.Can anyone tell me the exact part numbers that should be on a 1990 GTR turbo .
Cheers
I was under the impression that the form they gave me at my first inspection ( I thought it was just a matter of checking the engine number ) at Sturt road centre gives you and exemption. The form is called " application for exemption from the fitting of a compliance plate ". The car has been registered in QLD and is currently registered in VIC. The car has a Vin plate attached. I have paperwork from ISASO compliance centre in QLD and receipts ($1281 ) for the compliance done in July 07.
I am new to this so If you know anything that will save me a re-inspection fee , I would love to know about it.
Cheers
^^ Same here. My car doesn't need compliance plate either. People from canberra that do compliancing told me my car never got one cause it was imported under some old scheme... and my car was imported sometime in mid-2005. I don't get it, cause I know many cars imported in 90's that have compliance plate... but as long as they're fine with it I dont care...
Yeah, the differences between SEVS and RAWS (15 year rule which no longer applies)
Not quite sure what the diff is but I think the cars imported under the 15 year old rule can get away with a little more...
-D
I took my car to Vehicle inspection and not the regency place. They're right near eachother though. My car just got imported from Japan and all it needed was a Vehicle Inspection. It's on Narweena (sp) St Regency. There were plenty of interstate cars there being checked. Maybe give them a call and see what you need to do?
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
