yeh, otherwise we would all change to WA plates and laugh at the traffic cops as we drive past, screamer with external wastegate fully open running 25psi through our highmount turbo!
i got defected 4 tyres
yay
thougth id come 'let it out' on here haha
'random' breath test on a side street at camden park, while on way home from gf's
can drive it for 72 hrs, after that i cant drive unless im going to tyre place or 2 cop station to get it cleared
and they even charge u $24.50 to get it cleared!!!!
yay
Just make sure the rest of the car is clean, i got a cop shop defect in my old ford for tyres then at the copshop i nerly got sent to the pits for being to low
yay
I wouldn't be complaining with that.
yay
Dude thats nothing compared to going to regency mate
and why do people always whimp out on getting the most important thing for their pride and joy.
drive with bald tires....you deserve to get defected
Afraid I must agree there.
Must have good grip for all occasions!
I wouldn't be complaining about a $24.50 charge either. Thats minor ... not even half a tank of fuel.
Edited by RubyRS4
yay
lol, dude, cop shop defects are piss easy, wouldnt even stress. just make sure u dont get double defected when u get there.
they wernt that bald where it would b dangerous, its only the inside 2-3 cm where its like almost no tread.
and i aint complaining about the money, just bitching cos i was in a shit mood.
I know you were not complaining mate
just trying to make my point on people with bald tires
the inside 2-3 cm is where it matters lol
Stupidest thing I ever did ... went to Phillip Island for the MotoGP, and did a nice burnout with the bike for the crowd ... a few times over a few nights actually.
Silly me didn't think about being able to ride it back home ... and couldn't get another fitted by any shop around that time of year.
Rode bike back home and got as far as 30km outside Bordertown before the tyre blew. :) It made for an exciting moment having a blow out at over 110kph. :)
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
