what he said ^^
emissions test is one thing, youll need to have en engineer hire out a test track for a day and test out the brakes etc etc.
Emissions tests are easy to get past, its the other tests that an engineer has to do that cost a lot more. Best bet is to call up a regency approved engineer and have a chat to him about it.
but if its a bigger turbo and same engine why would you have to change brakes?
From what I recall it's about 345mm eyebrow height (ie: from the middle of the wheel to the guard).
SA Transport document
They've since replaced the document on their website with one with almost no info, so this one should still be good.
Suspension height
The ride height of your vehicle may be
lowered, subject to the following conditions
being met:
• the suspension retains at least two thirds
of its original travel
• the distance between any part of the
vehicle and the ground is not less than
100mm.
The suspension height can be measured
in one of two ways.
>>Source<<
because youre increasing the final power output of the engine and changing the way it behaves. good thing about skylines is that they come with fairly big brakes anyways so a set of good pads/rotors and fluid are usually more than enough.
  • 4 weeks later...
Hey Guys, just copped my first defect for my 33 last night on my way through pt wakefield coming back from a weekend on the YP. only just put a new exhaust on that weekend! coppa looked over my car for a fair while, its pretty much stock besides my 18s zorst and pod filter. after not finding much he eventually deccided my exhaust was too close to the ground and im off to regency.
problem is i will fail and eyebrow height test atm by about 2 cms so need to get hold of some stock springs :blink:
that will probably eliveate my exhaust clearance issue too.
anyone got any lying round??
also anyone been through with 9.5 inch wide rims on the back???
go through with 9.5s and your bound to fail.
also , id just replace the exhaust with a stock system from the cat
thats what i did on mine and i passed with flying colours
your also going to have to do more work on the vehicle to make sure everything else is up to scratch as they will go over the whole car.
also make sure you have an english tyre placard on the vehicle (usually affixed on the drivers side door jam)
chuck stock wheels on , stock exhaust and stock suspension in and you'll pass
yeah, sound advice damage, just lined up some stock rims and i still have the cat back i just took off. hopefully someone has some stock springs lying around and ill be sweet. think i might get my bushes and tie rods ect looked at before i go in just to be sure.
Failed a regency visit recently for a few minor things, anyway I had my car booked into the mechanics today to get my $120 worth of wheel bearings (cbf doing them myself) and $50 worth of child seat anchor points installed, spent $50 on a permit to drive it there as well.
10 mins after I drop it off I get a call "Your car already has child seat anchor points, also your wheel bearings are fine it is just a $40 HICAS arm thats stuffed".
Pretty bloody annoyed, you'd think regency would make sure before writing these things on the notice that you do in fact not have them. Could have had it on the road a month ago as the HICAS arm is a piece of piss to replace, not to mention the wheel bearings and anchor points I now have to sell second hand.
Anyone else had an experience like this? I will be writing a written complain to them about it after I get my car passed, would send it before but I don't want to step on any toes before it gets regod. Is it likely I will get anything other than a mild apology?
Edited by Rolls
try and find a local MP that'll be sympathetic... some of them are biased, but some of them are really good in looking after their constituents
-D
Wouldn't bother complaining to Regency. What the f**k are they going to do? Throw your letter in the bin
If they get enough of them they might do something, I'd like the mechanic who inspected my car to get some feedback however. Maybe if someone tells him he might look a bit harder next time and not waste someone elses time.
I don't really expect them to do anything for my benefit, I just want some heads banged and hopefully some improvements. It can't hurt sending a letter.
i went though with my car yesterday looked over all the car as expected all the initial problems had been rectified which was fine. but he cleared me of everything apart from my headlights, i have the factory zenon hid's for the 34 and they didn’t pass me? is that right, I questioned him and he said they weren’t end of story and was a real wank about it. I said about they newer BMW's n all that with the HID's n all he said was 'well this is a nissan not a bmw' rather annoyed because i was really polite n calm with him n got nothing but a rude old man.
What do you guys think? do i need to now find some non-hid headlights? is it true that there not legal?
Edited by Volk34
The headlights are fine but they have to be fitted with Halogen globes, HIDs are only legal if the car is fitted with auto leveling headlights. BMW = Auto leveling, Skyline = no auto leveling.
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
