wow.... so what can you do from here??
obviously you have proof that the key was in one piece on arrival!!
i can see this going on for a while
+1
Thats just wrong.
Wow the f**k can you accidentally break a key in half? :D
****HERE TO HELP*****
If anyone is after a set of 4 standard wheels with brand new tires for regency send me a PM on here or contact me on the mobile 0432 581 798.
-lewis
That is very kind of you Volk, ill defiantly keep you in mind if i get defected. Thanks again.
i was done on the night i got my skyline( with my p plates) was done at the bay for fog lights my turbo timer and boost gauge where nicely lite up blue and clearly visable and the cop even looked at it but decided to give me a warning. not saying anything about the mysterious blue light, i was amazed once they left i noticed they parked about 50meters away asif waiting for me
all in all very lucky
Just got out of Regency - went by quite nicely I must say. The guy wasnt too thorough and was quite friendly. Even had a couple other inspectors pop over to checks out the GTR and even asked a few questions... one of them about the baseball bat in the back seat which is a steering wheel lock in the shape of one lol
Failed for R/H and L/H front top control arm bushes - understandable, the wheels wobbled like they were going to fall off haha
steering back boot split - easy fix
No defect issued and only the failed items will be re-checked.
Hopefully Boostworx comes through with the goods tomorrow as they said so I can fit them up for my re-inspection on Friday!
If not Auto Parts Professionals can get them in that day for you. They got front upper inner and outer nolathane R32 GTS-T bushes in that day when I called up, took about 4 hours for them to get delivered, not to mention they were cheaper than anyone else I called.
They are on main north road next door to city dismantlers and their number is 8260 2044
Had the re-inspection today... passed but this inspector discovered a couple things the previous inspector didnt but because it is a re-inspection he couldnt add more things to the list to send me away again so he passed me. I replaced the bushings on the upper control arm as told but there was still play in the front driver's side and it was coming from the knuckle ball joint thing... and it had un-tagged braided brake lines(non-ADR approved).
That was good of them to not make you come back. I've heard stories of being going back 3-4x
I had a similar issue where they noticed play in the wheel, put it down as wheel bearings but it was in fact hicas arms, was lucky the mechanic picked it up.
Had my car defected tonight at the new Gepps Cross Shopping Centre, was a car cruise, was doing nothing silly, cops swarmed in and went over everyones cars. I got done for a Boost controller unit that isn't even plumbed up/connected or anything, exhuast too loud, exhaust flap silencer, ride height 20mm under legal height on rear, front was ok, coilover suspension, pod filter. Total $681 fine, but because i have the car registered with 2 names between me and another member in my family as joint drivers, the officer tells me they will also receive a $681 fine. Thats rediculous i say. So here it goes to get the car ready to go through regency, anyone got anyways to help me out. Much appreciated
$681!!! what the f**k since when is getting defected a fine able offence?
Im dumbfounded. I would fight this in the court. Theres no way they can make two people pay the same price for the one minor offence.
-D
WOW You got reemed pretty good! What cruise was it? RCK? Anyone doing burnouts on the cruise? Someone must of reported to the Police about burnouts or something for them to raid the place and defect you like that...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
