Hey Guys,
Just a heads up... I think the boys in blue are doing a crack down as we speak as i have noticed alot of defect stations over the past 2 weeks especially down south near Seaford...
PLUS: when you get pulled over at a defect station on the side of the road, do they pop your bonnet??? I was deffected about a year ago, and they booked me for ride hight and they didn't pop my bonnet but i was thinking as my car is nice and stock on the out side appart from mags and front bar, weather they would pop my bonnet and look for other things???
Cheers
Jamie
Ive been through 5 times and never had to put a stock exhaust system back on.
Last time I went thru I thought it was kinda loud. Turned out fine.
Turbo timer not just disconnected but fully removed.
It's illegal to have a turbo timer installed? How come i can pass a roadworthy with it connected though?
Hey Guys,
Cheers
Jamie
Never mind...
Car is completely stock engine wise...
However, is it illegal to have a front strut brace or a boost gauge mounted just on top of the air vent of the drivers side???
Cheers for your help :worship:
Strut brace fine. Boost gauge no
Depends where the boost gauge is, if its in a vent or down below the dash it is fine, on the dash or a pillar you can't have it though.
Turbo timer is illegal because if you have a crash and the car get a fuel leak and it keeps running, sup massive fire. They shouldn't have given you roadworthy with it connected.
wow didnt know lol thx i went to 3 different mechanics to.. and not 1 picked up on it lol.. guess im lucky then
Edited by nismo07
hey guys i want 2 vehicle identit inspections at lonsdale inspection station i want 2 get my car pass for it 2 be in SA rego because it was from NSW so all the numbers line up so all that pass but they defected me for fibre glass vented bonnet and adjustable coilovers and boost controller.. when
i go back there can they pick on anything other and what they said 2 me to fix ? thanks
Edited by MAD R33
what did you expect lol...
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
