^^ Danny with age like that on your side you may need to retire and mod down to a RB25DE hahaha
The elderly and turbos do not mix unless attached to a 2.5L Diesel towing a caravan ;)
On another note when is the next wreck coming in???
  • 2 months later...
I got defected by a wanka cop for bov, blue parker lights and low beam turning off when high beam is on which is factory stock not a wiring problem he also thought the turbo timer was a boost contoller! the cop then said i have a week to take it to regency! I explained i only just bought the car 3 dsys ago and was gonna change the stuff! I asked why i couldn't take it to a cop to get the deffect off! He said caus there not mechanics they don't kbow what there looking at! I asked if he was a mechanic he said no then i said well how do you know what your looking at! He then ssid get smart with me ill arrest you an fine you 500 for driving a deffecable car i said you can't do that!
turbo timers are an instant defect, illegal on sports cars and they're a waste of money. well they can fine you $150 dollars for each defect they find. there is no set time frame you have to "get it to regancy" even if it runs out of rego just get a day permit.
To the guys out there that run a greddy intake manifold, have you even been defected for it? Or can you get defected for it??
Cheers
Get an idle emissions test and send in an application to modify your vehicle, they will come back saying you need an emissions test, once you have that you can go to regency to have it inspected and then you will get a nice piece of paper to put in your glove box saying you are A-Ok, if not then you are up to the mercy of the cop.
Actually even with the piece of paper you are up to the mercy of the cop.
You can get defected for your exhaust not looking standard, you can get defected for things that do no even physically exist on your car so if they want to defect you, they will.
Basically if you draw the wrong sort of attention, guaranteed defect no matter the condition of your car.
Edited by Rolls
Just play the game as best you can and don't drive like a dickhead and more often than not you will be fine. I got an application to modify my car with all my mods listed, idle emissions test and keep the inspection record in my glovebox, if your car looks stock, you show them this and don't act like a twat you'll be fine the majority of the time,
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
