Had a quick search and couldn't seem to find an exact answer to this.
Just took the head off from the RB25 and figured i'd clean all the carbon build up on the tops of the pistons while the heads away. What's the best thing that will dissolve/clean away all the carbon? Metho? Kero? I have no idea...
Cheers
https://www.sau.com.au/forums/topic/247044-cleaning-carbon-build-up-on-pistons/
A soft aluminium scrapper, and sometimes a small screwdriver used as a peen tool and the carbon pings off [don't use it too hard, the idea is to shatter the carbon not mark the piston]. Used correctly both tools will remove carbon without damage. Then your stuck with carbon soot falling down between the piston and the bore and sitting on the top compression ring, but it shouldn't last long once you start it up again.
I've heard Water Meth Injection will do the job nicely..
Haha i was actually thinking then when i saw how much crap there was on top of the pistons.
Ill try some of the suggestions, thanks a lot guys.
becareful not to go too silly, if the engine has some kays on it and you get aggressive and dissolve the carbon build up around the ring (lands, etc) etc it will blow smoke......
Edited by URAS
Oh ok, cheers Trent. Im getting the head done at that Lewis engines place that you mentioned in Adelaide, see how it goes. You end up getting a head off of them?
Edited by PM-R33
im building a pretty crazy 26 atm for a customer so i should be sending one over there (mine) to test the waters first in about a fortnight or so..
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
