  • Replies 56
Originally posted by Roy
...the R31 with GTR rims, looks tidy, any more pics.
that's my car mate. I aint got the link for pics here (not on my PC) so PM me if you want more. It's on of 800 GTS-R's ever made. And it goes alright.
Or if ya want, e-mail [email protected] i got a few more that aint on the net :D
But yer... Megz... those photo's have done the rounds now huh :D
that car and 6000RPM, you hit boost and just hang on.
RWD... light as, its really something to be in to understand
To give you an idea of the sillyness of this car before it's rebuild... in 3rd, sam mashed the pedal and in 2 secs this car produced enough smoke to fill the entire street with smoke.
That's how crazy the wheelsipn was and that was with semi comps on the rear of it when it hit boost, just two fat black lines down the road.
And i can vouch for sam's driving, after seeing 1st hand the way he controlled that can i can definately say that man can drive.
he still struggles with my clutch though :shake: :shake:
yeah te car is awsome on testing on the dyno 4 th ran out @ 280 kph :)we believe the car was used for wagan and for drag stuff if it hooks up 10 for sure.
it is the one car that has left a lasting impression.
do you why cause I could get used to driving it :D
yep niotto's and slick are on the card remember peeps this was only at 16 psi wait till it hits 28 psi or 2 bar :D
Originally posted by meggala
remember mario made well over 450 rwkw on stock internals tuning is the key
I was not implying anything megs. Just curious. Cant wait to see it run some numbers. I know tuning is a very important factor in the life of an engine. Good luck to everyone involved
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
