  • Replies 719
Really? Was that on the old website?
Would love to get the go ahead on the Ultima >_<
I vote that at the end each entrant be allowed one lap sideways. Mmmm, wonder who's done that before...
I still can't believe i got in trouble for this, talk about fun police.
It was the most entertaining thing we saw all day... You definitely had the support of the crowd over at iced coffee, but we all knew it was a matter of time until you saw a black flag waved at you :P
Nah Jack the Radical is a great car to drive,,,proberly the best race car Ive ever driven.
My old Capri sports sedan was by far more of a hand full.
Neil.
Out of curiosity what's the best times you've done in both cars Neil???
Nathan, what times did you end up doing? Its an RB25? What sort of grunt and suspension did it have. Looking at getting a feel for what i should be aiming for from a full weight GTSt at Oran Park on street tyres. I figure if i throw on semis then i am a fair chance of getting a similar time :(
Nathan, what times did you end up doing? Its an RB25? What sort of grunt and suspension did it have. Looking at getting a feel for what i should be aiming for from a full weight GTSt at Oran Park on street tyres. I figure if i throw on semis then i am a fair chance of getting a similar time :laugh:
I did a 1.20 with 280rwkw and Federal RS tyres. I'm running an rb26 with a gt3582, retuned it last week on e85 and it made 320rwkw.
According to natsoft you did a 1:21.2...
http://www.natsoft.com.au/cgi-bin/results....07/2008.ORAN.SL
Roy, I say you'd be doing the same times as DRIFTER or maybe quicker with re55's, providing you stay on the black stuff.... :laugh:
nah, I reckon my Supra on road tyres would run 1:21s this year. It did a 1:24.9 last year on Federal 595SS which were hopeless. The Kumho Ecsta XS tyres (180 treadwear) dropped 2.2 sec off Lakeside and 2.5 sec off QR Sprint times. I'd expect closer to 3 sec off Oran Park GP due to its length and the nature of the course. Plus maybe half a second from the slight power increase from the FMIC and FCD and 1 bar. It was stock last year.
Roy's car should have similar power in a much lighter body (Supra is 1640kg with driver & half a tank) and better tyres in Open class. I reckon 18s too.
Roy, I say you'd be doing the same times as DRIFTER or maybe quicker with re55's, providing you stay on the black stuff.... :)
Dam Natsoft get's in the way of a good story.
Well i was back in Melb for 1 week and i got absolutely nothing done on the car. So it will be probably be running in its current state of disrepair rather than with its new bits.
So looks like i will be happy with a 1:20, and stoked with a 1:18. Either way i just hope the car is solid for the long drive back to Melb.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
