I was looking at putting R88s on my GT-R and ended up going with R1Rs - haven't got them on yet so I can't give you a definitive answer about their performance.
When I was researching, I spoke to a rep who suggested the R1Rs over the R888s, firstly because they obviously wear a lot better (think about the percentage of time you'll spend on the street) and also, being a newer design than the 888, has grip levels approaching the 888 without being so reliant on buffing or having good temp in them for max grip. Worth thinking about if you're not planning to be at the pointy end straight away.
I suspect you'll find the 888s on eBay are parallel imports, and GGG compound rather than GG. Naturally Toyo are going to protect their turf, but this PDF does have some valid points.
http://www.toyo.com.au/RacePDFs/Bulletin%2...oxes%20R888.pdf
Be interesting to hear of your experience with the R1R's in due course. I suspect they would be significantly slower when doing laps than R888's or any other true semi slick although they may be a good dual purpose tyre.
  • Replies 42
Are those 888's on ebay from st george tyres?
I used them before, was happy, got quite a few days out of them, but need new tyres asap also
So the 888's dont last too long??
would you be better off getting re55s and paying the little bit more??
Re55 are supposed to be quicker than 888's. Gary wrote some interesting stuff on the IPRA forums:
Just when it was getting interesting.......the problem I am having is that we have tested pretty much every tyre on the CAMS list and there is a mixture of strengths and weaknesses.
Some simple examples;
Hankooks, great under brakes and power down but deficient in corner speed, don't like a lot of slip angle, relatively poor wear.
Kumhos, not as good under brakes, similar corner speed, don't mind a lot of slip angle, good wear characteristics.
Dunlops, good all round, very predicatable and stable performance over many laps, no big advantage anywhere but ended up being our choice
Bridgestones, OK under brakes and power down, the best corner speed, pace went off them noticeably on a hot day, average wear
Toyos, average all round performance wise but great wear rate
Hoosier, not availabe in the right size
Yokohamas, OK all round, significantly higher green tyre advantage than others, average wear
Falken, poor under brakes and power down, OK corner speed, Ok wear
Testing was over a number of days, using a crew of 6, with 3 drivers and utilising the necessary suspension adjustments made to optimise each tyre used. We have double adjustable Proflex shocks, adjustable ride height, many spring rates to choose from and a good range of camber, caster and toe adjustments. Being a production car, anti roll, ROC and CoG adjustments aren't practicle.
So if I had a car that was bad under brakes I might well be better off choosing the Hankooks, using their advantage in that area to compensate. Conversely if I had a car that was good under brakes, but lacked corner speed then the Bridestones would be the go. If I was running on a circuit that was heavy on tyres then the Toyos would be an advantage. If I had a car with a lot of power and needed good power down then I wouldn't pick the Falkens. Note, no wet weather testing, that adds a whole new dimension to the equation.
Hence my conclusion that there is no perfect tyre, they all have compromises, some more than others and the best tyre for one car is unlikely to be the best tyre for every other car. Worse still, even on the same car, the best tyre for one circuit may not be the best tyre for another circuit. That's why a free choice of tyres is always a category's less value for money decision when you have guys who take whatever advantages each tyre gives their car and whatever they can get on each circuit.
R888's last longer, but don't have as much grip.
RE55's have more grip, but don't last as long.
If you're chasing times don't bother with the R888's, but if you're doing targa or something requiring a long tire life, they are quite a good compromise.
That's because Falken RT615s aren't an R-Compound tyre. They won't grip anywhere near as well as the R-Comps everyone else is suggesting, nor will they last as long before overheating.
The RT615s are not a proper circuit tyre. In a motorsport setting, I wouldn't consider them for anything other than a wet weather tyre or a hillclimb tyre.
I used them for Dutton Rally and found them to be a great allround tyre.. I will get a few more days out of them as well
Some of the guys that do the multiclub super sprints use them regularly and happy with them
Angus,
Sorry for late reply - What I meant was I have done quite a few days, more than I thought I would! So they lasted quite awhile compared with other mates who have used other semi's and didnt get as much track days out of them.
Mine are now just about bold! haha
So I'm shopping around myself....
Im thinking some RE55's....give them ago when the budget allows haha
slapper, did you have them buffed? full depth RA1 is only recommended for use as a wet. Hornibrook Motorsport can buff them for you - its not that expensive. They'll go at least a couple of laps longer after buffing and you'll probably get more life out of them too.
Not buffed although they are almost worn down to a "buffed" state - thanks for the tip, will get Craig to have a look at them all the same. Seem too way soft and not enough stiffness in the sidewall to be anything more than a wet, great street tyre though!
they get better (on the track) as they wear down. They do have a very soft sidewall for a semi slick and a different 'feel' as a result. But I've only used them on a very light car so I can't say what that soft sidewall would be like on a Skyline...
sounds to me like there isn't a bad semi. for my case i haven't driven the car more than around the block as is isn't registered and i am looking to do my first track day early next year so value for money is probably my best pick.
I'd go with the r888's on ebay. i'm still waiting to hear back on the compound they have. but they seem to last quiet some time and at an average of 350 per corner you cant really complain!!! i might even use them for street duties they are pretty cheap and performance sounds pretty good too!
Edited by Angus Smart
well we are alot closer than you to antartica, penguins have been known to roam the streets of hobart :(
the dunlop dealer in town sells the r's as a recomended tarmac rally tyre, as it heats up fast, but is durable.
Edited by sav man
They are all too expensve and part of the reason why my car was absent from the track in 2008....i sped $4500 on tyres in 2007. That is abou tmy budget for the year for entry adn fuel etc :( So i stretched the bank too far in 2007 :/
So the obvious question, is a 245/40/17 semi slick cheaper then a slick from the same manufacturer?
480 i got quoted for 255/45/17 from the ebay r888 supplier
p.s. i actually got quoted 380... sounds a little better now doesnt it..
r888's in gg compound..
asking taleb now :thumbsup:
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
