I can get a brembo typhoon GT front and rear kit for ~$5000.. it has the same
calipers and same rotor dia (355 front / 330 rear) as the r34 gran turismo brembo upgrade
kit, which is ~$10000 now (or more).
So does this mean the typhoon kit can be turned into an R34 kit, with four brackets, and
different aluminum rotor center pieces?
This 2006 topic says it may just be a case of custom brackets and a handbrake solution.
http://www.skylinesaustralia.com/forums/Fo...amp;mode=linear
$5000 is a lot of incentive to get some brackets copied (which brembo won't sell).
Edited by r34nur
https://www.sau.com.au/forums/topic/248460-adapting-brembo-gt-kit/
The Typhoon brakes use pistons far bigger then those sold in the F50 kit. From memory it is 48mm and 44mm , compared to the normal 44mm and 40mm.
The rotors can have custom hats made and also custom mounts, but they will cost about $1000 min then you wll still need brake lines. So $6500 is a lot of money bt anything is possible. Frankly you can get Brembo F50 calipers for the fron for about $2500 and GTR rear calipers for about $800. Then go fishing for rotors and front brackets which means you will go close to getting the whoel setup for 5k
calipers and same rotor dia (355 front / 330 rear) as the r34 gt brembo kit, which is
don't know where you got ur prices.
but complete r34 gtr brembo brake setup (caliper, disc, pads + stock lines) can be had for between 2.5 and 5k MAX!
The Gran turismo kit is currently $3200 USD for the front (355mm), so I don't think it can be
had for much less than $4500 locally with the dollar now. And a similar
for the rear. This is 6-pot mono for the front ..
So that is getting on for $9000 aud even with discounts.
(UAS list a monster package at over $10.5k (8 pot front 380mm) but that price
is already out of date, it will be near to $12k now.)
Yeah the stock R34 brembos can be found for $whatever, I already have those!
I'd sell them and buy the typhoon set. But Roy thinks it sounds like trouble..
The gran turismo kit at least the 355mm I got quoted on,
is a 6-pot type-R monobloc front, not f50 front ..
same with the typhoon kit - 6 pot, same caliper.
Edited by r34nur
Really, so is that the latest Typhoon? BF or whatever its called? The FPV Falcons i have paid attention to ran 4 pots. FPV must be spending some biccies on brakes :)
I don't know if came as an option, or is just an aftermarket brembo brake-upgrade kit that
is otherwise available at a more reasonable cost [than the r34 kit is]. probably the latter.
sorry i through you talking about stock brake setup.
But there are deals out there
for between 3.5k and 4.5k + shipping
AP racing 6-pot 354mm disc (fronts only)
Brembo F40/F50 kit 340mm disc (front only)
Greddy/Alcon 6-pot 354mm (front only)
Even with the poor yen good deals can still be found, but i would advise at tring to find disc locally as they can be heavy and do increase the shipping by afair amount.
There are alot of options out their so i guess it comes down to if you want to buy a bolt-on kit or just buy the caliper and then get your own dog-bones made up
Edited by [Michael]
Also, there are a number of considerations with trying to adapt the FPV gear to your 34... with enough $, you can do it.
off the top of my head, these are some of the things you have to consider
1. will the front rotor offset (how far in or out it is, in relation to the hub) work on the skyline, and is the stud pattern the same? will the wheels clear the rotor and caliper, given this offset
2. will the rear rotor offset work? What will you do with the hand brake assembly? Adapt the FPV one, or run custom rotors and rear hats over the handbrake drum?
3. do I need custom brake lines make up to suit (probably likely)
4. will the caliper configuration work (be possible!) with the skyline front/rear knuckle assemblies? They may not physically fit!
5. what is the cost of custom hats and dogbones? Note that radial mount calipers are MUCH easier to make up brackets for, than lug mount (lug is what the factory brakes are, generally A/market are radial). My recollection of my hats were ~500 front pair, and ~250 for the brackets.
6. brake balance - will the skyline master cylinder be the right size to push the larger or smaller pistons? will i get a pedal with no travel, or lots of dead travel?
that's just a start! I don't want to put you off trying it - i wanted to do this on my 32, as I could get some FPV stuff relatively cheaply - but in the end went with AP CP5555s front and factory 33GTR brembos at rear, with a larger rotor.
The ultimate question is - $7K will get you a bolt on solution from stoptech; you'll probably at the end spend that on the FPV setup. Also, the FPV setup may not work, or be a lot of farking around to get working.
hope that helps...
hope that helps...
Thanks, it does help. sounds like there are too many unknowns for a naive player..
race brakes sydney told me that they'd sting me for a grand a pair for custom
brackets, then I'd have to buy dba rotors for the rear as well.. i am sure i could
find the engineering for a lot less but you are right there are several traps along
the way.
the brembos fitted the the FPV have removable dog bones much the same as any brembo you would purchase as a kit
personaly i would look into buying new brembo or aftermarket rotors/hats and dog bones to suit the application and selling the ford dog bones and ford rotors obviously if the ofsets and mounts dont work out
i once purchased a Brembo GT-P 6 pot f / 4 pot r kit to do the same thing but moved it on. the offset of the GT-P brakes is very similar to the GTR offset, but the hub and stud holes are too large. then of course there is the cost of brackets, which at $1K for fronts seems a little high but comparable to quotes i've had that are equally, in my opinion, outrageous. tried getting GTR pattern DBA 5000s but it was like pulling teeth. the handbrake problem would not be easy to overcome either, custom hats is prob the only way. finally the the cost / hassle of adapting the kit and even then maybe having to stuff about with master cyl diam if there's too pedal travel just wasn't worth it. what you're being offered is really a steal for what it is - a great upgrade for a Ford. Holmart are selling VY/VZ AP front and rear kits complete (350mm f) for $3.5k. compared to what we are getting stung for GTR brakes it's amazing.
as suggested use the R33 GTR rears and try to get some F40/50 fronts with suitable discs and adapters. those calipers can be picked up quite cheaply, why no one has produced a kit with suitable 355mm rotors and adapters so people can simply add their own calipers is beyond me given the demand for GTR brake upgrades and the availability of the F40/50 off the Fords and from o/s. suggested this to one large brake distributor but no interest, not surprising if people are readily paying $6k for AP fronts or $1k just for brackets. current economic climate may make them reconsider.
stoptech looked perfect at one stage but i wasn't going to pay $3500 locally for a kit that was $2600US retail when the exchange rate was nearly 1:1. and company freight rates prob cost them $200. from what i can see they aren't selling many locally but neither are they dropping price. just al ittle too rich for me given that the distributor isn't paying retail either.
sorry but my research has not revealed any really cost effective and worthwhile upgrades beyond using R33 GTR Brembos. there is the K-Sport brand that I understand is similar to G4 etc but with dust boots, which are a legal requirement for a street car and share parts sizes etc with some other brands. i haven't seen them used for any length of time so i have no idea if they are any good when it comes to durability or safety.
cheers
Edited by Scooby
cheers
Since the car is R34 gtr, getting R33 rears would be a downgrade. But yeah, everything else makes sense.
Now with the exchange rate a full 355/355 stoptech kit for $7k from UAS is actually cheaper here than getting
them in the US let alone adding in freight and fiddling the declaration to avoid gst.
The k-sport/g4 kit seems to have worked out for several people.
I'm leaning towards getting stoptech front only and then checking on a track day to see if the rears are still
balanced to the work the fronts are doing. If they are overheating then I could try either a caliper offset kit
and better rotors from biot, or the stoptech rear set to complete the setup.
I spoke to Zeckhausen racing which is prob the largest S'tech agency in the US. They maintain that the S'tech fronts are perfectly balanced to the stock rears (and obviously S'tech rears) and warned me against using F50s, which they claim will upset the front / rear bias. The calcs I did comparing the AP6 piston and GTR Brembos showed not much difference to stock in terms of bias (which is not only piston area) and the small AP pistons suggest that this was intended to be the case. However the F50s showed significantly larger piston area and front bias. I think if you can get reasonably priced S'tech stuff then it's as good as anything else.
Have you considered the Z33 rears at 322mm? Interestingly the bias was still front heavy when I compared them with the F50s.
thanks, so the 350z z33 stock rears are bolt on? you mean the rotors only - which are cheap as chips on ebay - or the complete set?
i meant the complete set. can't say for sure they are a simple 'bolt on' as i've never tried them myself, however, for what they offer and the price they can be had for it's potentially an attractive option. also its the Z33 with Brembo calipers that you need to source, i doubt that making dog bones for an increase from 300 to 322 mm using the R33 Brembo would be fun (bolt holes too close) unless the lugs are extremely offset.
ronin 09 was looking at the Z33 rear upgrade but it's a bit of a pain in the arse from memory. in the end he bought a biot offset kit from me for his rears which comes with better/bigger rear rotors and new calliper mounts to position the calliper in the right spot. apparently even those are a little bit of work to fit.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
