  • Replies 42
let them each turn a lap in it. the bloke with the most spectacular time/lap/slide/roll/crash/scar/head injury wins. the loser buys the pints.
my moneys on bloodnut. hope your irish mate has deep pockets cause I'm bloody thirsty!
Meh, i have 35k burning a hole in my pocket. To buy a daily driver and go silly with my cheap club GTSt or keep my GTSt as it is as a fun daily and buy a serious track car that will keep me truly broke all my life. For the R33 i would probably dig into the sensible savings fund for some more dosh, but will most likely still be short of any asking price. :)
Especally since they have started development on it , so looks like Irish would win the tussle. But i like the idea of a match off...i can be pretty special when i disconnect my brain :)
lol.... Hey, if thats the judging, 'ole Fanta pants is a sure fire winner. Irish has spent the summer lapping the 'Ring in his modded 33GTR without touching a wall, so evidently, he's a panzy.
Irish is back in Feb, so if Team Bigtime can have it sorted by then he's a starter :)
Roy, I've seen the light, and I reckon you'd love it :D
Next year I'm teaming up with a mate to do the Kart Enduro Championship for fat farkers over 85kg. :) Twin engined 4-stroke Karts, totalling around 13hp. Nine rounds, races between two and 24hrs duration, longer races requiring ring-in drivers to get the team to three or four strong. There's a Lake Macquarie round, I reckon you'd be keen for a skid.
Are you sure that particular vid was with the car in rwd? It looks pretty stable for the grunt it would have running the TO4Z? If it is rwd then the lap time looks a lot better then the time you did to win the event and you should really start setting up rwd cars as it looks epic on the power down in 2nd gear and 3rd gear quick stuff
hey RBNT, Mark did come in rather stuffed, i dont reckon he took to many breaths
Roy definately in two wheel drive mate, the slicks were helping gear the power down heaps , michelin slicks they are bloody soft too.
we only had 4wd friday and saturday morning then if blew up. i will post a pick of the carnage when i can , i am going to keep the diff housing as a keep sake cant believe it came off so neatly!!
he is a few clips of mark slipping around some, i think he had to change his pants on the last one.... haha
http://au.youtube.com/watch?v=m7v4BliLpWM
hereis a vid when the car 4wd on the first day and mark was getting used to the track.
car is a lot better behaved, following a ver yquick gt2 around, it was a beautiful highly modified gt2 and also passing an r35 gtr
http://au.youtube.com/watch?v=A5mqAoCrXkc
Bwaahahaha, that last one mate, TRIPLE PEAK!!!! :( Uuuugly.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
