Hello. This and SDU are the only English-language Skyline sites I can find. I'm not Australian, but maybe you folks can help a Yank in need.
I have an R32 GT-R and I recently got new tires. I drove around for a while and I noticed that when I go over 70km/h, the steering wheel will slightly start moving to the right, but the car will stay straight. As I slow down, the steering wheel will straighten out again. It's kind of scary. This only happens sometimes. Also, when the HICAS light is on, it doesn't happen at all. This didn't happen before I put the new tires on, but I don't see how new tires would be the cause. The tires are the same size as the old ones.
Is the HICAS system doing this? I had a mechanic check the steering rack and he said it was fine. He's the same guy who put the tires on. I trust this guy since he's been my mechanic for a while and I know he won't BS me. I told him about the problem, but when he test drove it....it didn't happen (of course).
He recommended that I remove the HICAS system regardless of what is causing the problem.
I'm completely new to Skylines. I came from years of driving Impreza WRXs, but defected to Nissan.
Thanks in advance!
https://www.sau.com.au/forums/topic/248978-r32-gt-r-hicas-problem-help/
in thery hicas is meant to disable itself at high speed
so when you go over 70 its disabling but its default position is a bit off
so get a rear-wheel allignment i guess?
last sunday i ripped my hicas rear end out and replaced the whole subframe with a non-hicas one, i win :blush:
Firstly, if the HICAS light is on, that's an error, and HICAS is disabled.
Back to the problem at hand. You had all 4 tyres replaced? Or just front / rear? How are the tyre pressures? Did you get a wheel alignment with the new tyres? Have you checked the power steering fluid level?
As you know when you get new tyres you need to do a wheel alignment front and rear for GTR's as they are 4WD...
Did get one done?
Then check your HICAS Fluid.
HICAS is suppost to help you with your turning / handling.
As you drive over 80km/h and turn the wheel, the rear wheels are suppost to turn 1 degree in the opposite direction to help with the cornering.
mine does this sometimes aswell.
tur on the car...take of and when you hit sixty the steering wheel goes all wobbily. if you try put steering wheel straight it turns left. stop turn the car off and start it again and its fine :)
my mech said easiest fix would be get rid of hicas using a lockbar...so thats what ima do
  • 4 weeks later...
Hi All,
Has anyone found a definative 'fix' or solution to the problem "higeki" raised as I'm now having the same problem as him with the steering wheel turning to the right - it will eventually flick the car momentarially and the steering wheel will re-align itself back to straight and will drive normally?? But it's the scariest feeling when the car flicks like it does...
May need to look into a full wheel alignment asap?
Cheers,
Adrian
mine does the same
i have an aftermarket steering wheel which causes the hicas light to come on during long strait journeys.
my tyre pressures and alignment is fine (just got done)
when its happening i just turn off the car for a second, allowing the turbo timer to keep the car on, this turns off the hicas light and the problem goes away :P
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
