Well the last sprint for 2008 has been run and won*** (by me! :) ) so it's time to hand jive to next years calendar.
Don't worry about the impending end of the world (otherwise know as the credit crisis :down: ) - embrace KRudds mantra - and spend on shiny stuff - preferably with a Nissan stamp on it somewhere
Enjoy
Andrew
2009_track_day_schedule.zip
*** I won the event because it was against a bunch of 30 year old ALFA's. :(
https://www.sau.com.au/forums/topic/249048-2009-track-day-calendar/
couple of quickies -
1. Once i become an official SAU member can i attend any and all of these track days?
2. Does it require me to get a CAMS licenes in order to be able to pariticipate?
Whats the best way of transporting a non-road registered vehicle to these meets? I dont have a valid licesne at all atm.
1. Yes
2. Yes
Trailer...and track day requirements usually state that you have to have a valid road license to be used in conjunction with your CAMS license.
No - it's just too far for such a short time on the track.
There are also lots of closer events at the same time.
But you never know.
Have you driven Haunted Hills yet Andrew? If you haven't it's worth at least one trip, great little track
No, I haven't been down there yet. I will probably spectate at an event and make a call then.
1. Yes
2. Yes
Oops... I did a lot of events when I didn't have a licence. I'm pretty sure you don't need a road licence to compete in most events.
Just a quick question..
Are all those trackdays open class?? meaning can any car participate?
I'm aiming to attend the AROCA one held at winton on Sun, March 01.
I didnt get out much last year due to the engine letting go.. but all is ready to go now, just gotta run it in and tune etc.. so keen as mustard to get out there!! ;)
Hi Liam,
All the track days are interclub/all in these days. No one can afford to run a track day for their club only these days execpt for the Porsche club.
All you need to do is download the relevant club's supp regs and enter.
See you at the track.
Regards
Andrew
I didnt get out much last year due to the engine letting go.. but all is ready to go now, just gotta run it in and tune etc.. so keen as mustard to get out there!! :D
  • 7 months later...
hi everyone just a quick question,
i hvae a r33 gtr i do a few hillclimbs in it have got my vic membership and cams l2s licence so thats all good but,
my car has is road regoed and has a cusco bolt in cage that is not approved and the car is non log booked, now i have gotten around this because in the cams manual it states its up to them to allow it to run in the even where a cage is not required.
last hillclimb i did was in sa and they cracked it at me i turned around and said it a road regoed car im not welding a cage in i dont even need a cage in the car for this event, it is there for my own saftey if you wont let me run withit ill just un bolt it right now and ill run without a cage.
guess what they let me run with it.
but will they let me run with it over here in vic at track days?
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
