Hey guys i just brought my first r32 gts-t i was wondering which turbo would be my best choice. it already has a gt35r on it an its a laggy as f*k it starts to make boost around 4300 an full boost around 4600.car has wolf3d, larger unkown injectors sard fuel reg.custom turbo manifold with external gate etc etc.After around 200-230kw.what would be an ideal turbo that makes boost around 3000? any thoughts would be greatly appreciated.
https://www.sau.com.au/forums/topic/249380-gt35r-downsizing/
Have you driven a car with that much? That turbo is rated for 300+ kws or so... that's a big drop down!
I have a VG30 turbo lieing around (slightly better then an RB25 turbo)... you could highflow it for around 220 - 230kws...
NYTSKY mate i was thinking along the lines of a gt30 when do they start to make boost?a lot of people on here seem to be using hks GT 2530. Mlr mate with the cam gears what sort of rpm do u think this would lower the boost range by? thanks
Not sure mate, I'm looking into this as I'm having the same thing going on with mine, rb25 with gt35, tuner recons it will drop between 250 to 500 rpm.
Not doing this though till next year when its going in for a rebuild so no answer on this for a while from me, sorry.
I'm sure someone on here could give you a definitive answer.
Yeah i will do some searches on that an thanks man.
Unbiased opinion.
GT3076R would be good choice
But if it was me I could not go past the Billet S56-GT3 with .63 A/R hot side.
The S56-GT3 specs are pretty dam good
The S56 compressor wheel has a 56mm inducer and 80mm Major + (ETT).
Turbine has an exducer of 56.6mm and a major of 65mm and is made of 713C Inconel
Compressor map
Turbine.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
