Was just saying the EVO pro is $40 more for around same size; only difference is the pro will preserve data for 60-70 years vs 17-20 for the standard EVO.
I'm free tomorrow if you wanna tackle it then?
From what I'm reading on forums, most issues with MSY surround customer service in initial sales at particular outlets, i.e. usually noobs not having a clue what they are buying and walking in looking for the Harvey Norman experience. It's just an in and out parts supplier and that's why they are cheaper than anyone else / popular with a lot of computer techs.
There have been issues with warranty dealings in the past, but the ACCC cracked down on them hard and fined them big for it a few years ago.
I can't speak from much from personal experience...it wouldn't matter anyway, cause everyone seems to have their own good or bad story and it seems to differ from store to store...but the guy I dealt with yesterday was pretty friendly, even carried some stuff out to my car for me. And that's how I like to shop...no fuss, no upselling or anything...just go in there knowing what you want and come out with it.
ive had no issues with bootup and have tried 50+ games :P
main issues are SLI/Crossfire as there is alot of games that dont support it.. like the new need for speed for instance
You say that but ive never had a problem with sli?? not once :)
Unr33l: those are some impressive scores for single card, nearly as much as my gtx 680 sli!???
PC built! Fk it's quick to assemble them these days. Everything so modular and easy. Windows installation / boot up on SSD is a joke too. Thanks to Leigh for helping me with it!
No worries brah! half of it was already build don't forget!
Now to wore up the peripherals and get dat 3dmark score.
Yeah run 3dmark 11 it's what most people use, my guess is around 11,000 ish given your GPU not quite as good as what I had in it :P CPU / physics will be practically the same just the graphics score will change a bit.
dat gigabyte windforce, good looking card - still love my reference card 'geforce gtx' glow though :D
Edited by UNR33L
no problems, just a lot of games dont utilise both cards. When I was running SLI downloaded some tool that optomises it (and had some effect on games that didnt use it)
well.. tried to run 3dmark last night but couldent :(.. cpu was overheating, so this arvo got some beers and set too.. cleaned everything, the rad was blocked BAD lol. and applied new thermal paste to the cpu die and the ihs, has been 5 months since i de-lidded it..
EDIT: just made some more points
Edited by BrynDETT
Recently got a MSI Twin Frozr R9 280X but I think my 955 is now a bottleneck :(
Though the cooler/fans for the graphics card are brilliant and now have removed the 2x12cm fans I had on the side panel so the whole system is quieter now.
nice score mate! those asus cards are very nice heard many good things - what was your cpu at in that run? and what cooler you usinig? h110 or something it looks like? post up a link to the 3dmark result so we can browse through the info :) keen to see what I could get my 780ti in graphics score but don't want to go too hard :P I'm just running a modest overclock right now
Edited by UNR33L
http://www.3dmark.com/3dm11/7621438
not very much info on that page... cheers mate, cpu is at 4.8ghz at 1.42v.. the cooler is a thermaltake water 2.0 extreme pretty much exactly the same as the h110.. the software even looks the same..
be mean to it hahaha
now you just need to upgrade those 680s to 780s :P
This guy would win the e-peen thread:
http://www.youtube.com/watch?v=NR75NdUiQck
I'll be going full custom water in my x-mas break I think.. EK VGA blocks so dang sexy.
Edited by UNR33L
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
