haha Ash, thats why I found people buying SSD's and putting games on spindle drives to be complete idiots!!
one of my workmates got an OCZ Ibis drive today with the propietary interface (uses a seperate PCI-E card which is included), initial results look quite promising, loaded Win7 Ent x64 even quicker than striped Velociraptors or a Vertex 2!
That said, it's still 800 bucks on a freaking drive!
I think my SSD is starting to die, windows would freeze up randomly during start up & the HDD active light on my case will be permantly on & its not my other drives since it has no noise.
It is one of the 1st gen SSDs without TRIM support that I had for about 3 or so years.
FML I can't afford another one atm after I just below tons of $$$ on fixing up the car's cooling system... :(
So. Gonna upgrade soon:
Core i5 2500K (not overclocking though)
GA-P67X-UD3R
8Gb RAM (prolly some decent Corsair 1600mhz) (2x4Gb)
Asus CU II 570. Was looking at the 6970 but I'm swinging back to the CU II.
Currently running C2D E8500 + 4870 512Mb, and it's pretty fine for almost everything I throw at it. Running TRUE on the CPU to keep it cool and QUIET, and the TRAD2 on the 4870 (plus 2x 92mm fans, again, cool and quiet). Biggest thing is quiet. If anyone can suggest why a 6970 will be quieter and cooler than a 570 I'll listen :)
Suggestions? Don't wanna blow the bank, got major service on the liner to do. Got all the HDDs I need, etc.
GA-P67X-UD3R
Pretty similar setup you are running to what i have. Except i have a 5850 TopCU - it still makes mince meat of all games.
I'd suggest holding out to be honest. The next update to architecture is due in 6 months or so
i5 will also be dead not soon after that if memory serves me correct and hence you'd be better off going i7 2600k if you wanted to update, least you have an upgrade path.
GA-P67X-UD3R
Don't get p67. Z68 is about to come out. (I already have one as some stores are already supplying). So I'd get a ga-z68x-ud3r.
And go i7 2600 if u like however if your REALLY penny PINCHING go i5 2500. Either way both sandy bridges use 1155 socket.
But for the minor extra cost. U can get the 2600k and just up multiplier to 40-45x. Done. Safe OC. 30% increase in performance.
I personally would wait for next gen of cards. Gtx590 and 6990 are the end of this gen if you follow previous gens framework. (dual gpu, single slot have been end of gen usually)
Ram is fine. 8th more than enough. 1600. Get something at 1.5v if you can. Not too vital.
Would you consider a small SSd just for windows etc? Really speeds things up lol.
What PSU u gonna use?
Also I personally wouldnt wait for the next architecture change. The VERY next change is to IVY BRIDGE. Wich still uses 1155 socket. So no point waiting.
Next socket change is LGA2011 (as it's called so far. Might change) but it will be same price point as the 980x etc are now. Be prepared to pay alot more. 1000$ etc.
Edited by ShiftyTys
z68 is only useful if you are going to use Quick Sync. Were I to upgrade (happy with the i5 I have, ill just overclock for now), I'd be all over P67 + NF200 (for teh SLI)
Small SSD + data on spindle drives are impractical and self defeating for gaming for obvious reasons. I'd be inclined to get a 240 gig SSD if anything other than Raptors.
There is no real reason to go for a 2600 if you're gaming and not running a bunch of multithreaded workstation apps (hyperthreading being the main difference); the price / performance ratio drops right off between the 2500 and the 2600 (2600 is still great value though!) Don't bother with a multiplier unlocked CPU if not overclocking though lol.
The dual GPU cards are a waste of time and for those who are scared of SLI which is faster for the same price or at times even less. I haven't had any issues at all with mine, despite a lot of naysayers still being convinced things still are like they were during the time of the 8xxx series.
AFAIK, LGA2011 will be the uber expensive 'enthusiast' chipset and processors (given Intel's usual "tick tock" product releases). Overpriced to the max.
Go for more RAM speed over latency (I'm a Gskill fan myself), most people I know myself included are running 8 gig these days.
z68 is out. And has more features. SSd caching efi bios unlocked overclocking FSB overclocking. AND heaps of stability improvements over p67 (I know because I went through 4 p67 gigabyte boards that ALL had power cycling on boot and reset issues.
While waiting for my RMA to come through. Again. Z68 came out. So far. Zero issues.
I won't use SSd caching or prob even the efi bios. But it seems silly to me you would buy something gigabyte isn't even making anymore. and that other manufacturers also had heaps of issues on (asus had random bsod) esspecially at the same price.
Edited by ShiftyTys
Was looking at Antec Truepower 750W. Running a Basiq 550 at the moment; always had a good run with Antec.
Was half-toying with a 60Gb Vertex 2 just for OS and applications; I'll install all my games and shit on my 2Tb WD Black. I won't be overclocking; I just wanna put it in the case, have it run, and be cool and quiet (hence the extra ~250 on cooling for GPU and CPU currently in my PC), but the 2500K is $10 more than the 2500 so meh.
Image below for what I was thinking (PCCaseGear):
Hadn't 100% decided on RAM yet, not too fussed even if I get 1600. ~$150 for 2x4Gb sounds about right.
Plans might actually be going on back shelf at the mo; working out what's more important, new PC when mine works fine enough, or trip to Europe with the missus and her not having the shits with me. Sliding towards the second... Not like I have all the time in the world to game anymore :(
You dont need a 750w PSU for that GPU or setup IMO.
Get a Corsair HX650 or similar. No need for bigger PSU and you wanna aim for the sweet spot anyway.
I've used Corsairs in all my builds and my own runs a 650 and has 24x7 for 3.5 years now almost :)
Are those Corsairs modular? That's my biggest tick in the box; Got an Antec P180 case, and thoroughly enjoying using as little cabling as possible :P
EDIT::
http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_354&products_id=12918
oh goodie, modular!
And yeah, I knew 750 was a bit over the top... Apparently I'll be fine with the 550 but I'll keep it with the older components and make it a spare box :)
http://www.antec.outervision.com/
I run SLI and 4 drives on a 700w lol, though I'll likely up it to an 850 just to be on the safe side
I got an 850 to be safe lol. Hx850 modular corsair.
Running 2tb caviar black. 2 tb samsung, 1tb WD, 120gb SSd. gtx285 (takes 2x6 pins for power). Bluray rom/DVD burner. And an OC CPU.
Oh yeh. Running 3 x 23cm fans and a 12cm fan. And both massive fans (12cm and 14cm) for my CPU cooler. Love my HAF932 and Noctua d14. :)
But yeah. I wanted to be completely safe and future system proof so I went the 850. Plus I was overclocking so I'd rather be safe. Too many issues caused by a shonky psu.
Hmm, Why not,
Case: Lian Li X-900
Motherboard: MSI P67 Big Bang Marshal B3
CPU & CPU Cooler: i5 2500K @ 4Ghz, Cooled with a CM V6GT
RAM: 8GB Corsair Dominator GT
Monitor: 2 x dell U3011, Mmmm Dual 30" goodness
Graphics Card: 2 x Gainward GTX 580
HDD(s): Corsair Force Series 120GB + 18TB on my server
OS Used: Windows 7 Ultimate
Peripherals: : Logitech G15 & G9x
Cost me a good 6ish K, wishing I had saved it up for the car (Didn't have it at the time) :angry:
I think it's time to sell it off.
EDIT: Like k1netic I know a LOT more about PC's then cars, didn't know this place had a PC section lol.
That's not alot of pc for 6k lol. I'm assuming a good 4k went towards the 2 monitors and 18tb worth of storage lol.
Monitors cost about 2.6K alone and another 1.3K for the 2 x 580's, that's pretty much where all the money went too. :thumbsup:
Already had the 18TB worth of HDD's, have been building it up over the past year.
Edited by Converge
Lol. Nice. Bloody expensive monitors :O
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
