Hey,
I just purchased a R32 with RB25 in it. It has a Microtech ecu. Now the standard plenum was removed from car when i bought it, and a greddy copy was dummy fitted. After inspection, the standard plenum has a plate over where the AAC valve went, and its been sealed, and the new plenum, which owner said was purchased second hand, has had the hole welded up, and im confused as i dont know how the car will idle? I dont know a single thing about microtechs..but to me i would think you will need air somehow to make it idle.. Any Ideas? Anyone know of removing aac valve how to keep car running??? Problem is i havent started car yet cause its all in bits, and ive never heard it running
https://www.sau.com.au/forums/topic/250031-aac-valve-is-missing-from-my-car/
you mean so the throttle only closes 98% or something.... i heard this can be bad when you back off, the revs dont drop quick enough?? true or false anyone?
it is just the throttled body has been adjusted so that it is always open. this does not mean that it is all of the way open is may only just a little. i dont think it will damage any thing when u back off as long as ur not idling to high. but dont take my word for it.
the way that i see it is if nothing bad has happened and there ar no funny sounds then it should be fine
no you dont need aac... atleast that has been the case with a 4agze ive been working on... its running a haltech map based ecu.. so obviously the haltech didnt support aac so we blocked up the idle control holes in the throttle body and just set the idle with the idle screw... works like a charm..
The Auxaliry air control valve is there for the purpose of adjusting the idle under load of air conditioning or alternator load, it adjusts idle up to 500 rpm, the ecu also uses it to determine engine revs at idle whilst warming up, however it is not critical to the performance of the engine as it becomes redundant once rpm reaches 1500.
If your aftermarket ECU is running the AAC valve, leave it on.
To get a car to idle up without one, means you have to fudge things with timing.
To force a car to idle up, say if RPM drops to 600RPM, you throw ALOT of timing in, and it'll bump it up. If it's idling high, you reduce timing so it drops down. It's all in tuning the timing map, and fuel map to make it idle correctly.
Things you will lose though, are like the idle up when you turn the steering wheel, or turn the AC on or lights on.
Some ecus allow you to add or reduce ignition timing VS temperature, this is how they can idle up, when cold. But nothing else can be idled up.
You can do this whether the ECU runs an AFM, or a MAP sensor. You just need to know how to make it do it.
Last I heard, the Microtech can't control very many AAC valves. But if your ECU can, LEAVE IT ON THERE! It'll make life alot more simpler then "removing a few hoses"
thanks alot for the help guys, that sorts me out, My car never had one when i got it so i wont bother trying to hook one up, when i get it running i just hope she runs alrite, thats alot... if i have trouble with the A/C or the P/S stalling me ill just bump the revs on idle to 1000rpm or something.
Thanks alot for the help, Happy new years
ps...just for the record my old r32 had map sensors power fc djetro and it needed the aac valve, but when it was fully open was still not getting enough air so i left it on, but i also opened the throttle a little.
cheers
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
