  • Replies 2.5k
Posted Images
Good on Jensen and Rubens though. Button deserves to win after all his time in F1.
I can't believe Brawn GP won on its debut. And I can't believe Barrichello switched to Brawn GP after all his time with Ferrari. It's a pretty risky career move for both jensen and rubens to switch from teams that have years of experience in F1 to a fresh team that has never competed before.
Maybe it's the best career move yet for both.
We'll see what Brawn GP has for us for the rest of the season.
Makes me wonder how Ferrari will fare this year with new competition....
its not like they had a choice of where to go since everyone else had their drivers pretty much confirmed.....brawm gp is essentially honda with new engine parts, only team left and they were both in it before.....so why not
Yeh, awesome to see Brawn 1-2. Shame to see Vettel trip with Kubiza. Sux that Rubens plouhged into Webz, with all the drama of the race the RBR looked quick and with no damage on the car Webz could have easily finished ahead of Hamilton/Trulli.
Oh well, will have to wait to Malaysia....but the Brawn is simply too quick. It is miles ahead of the other cars for pace. Rubens in a beaten car was able to recover for 4th on merit, inherit 2nd. ANd Jensen was criusing with just mintaining gaps he didnt have to work all that hard to get. Then threw away time in a pitstop and was still comfortable. The car is simply a rocket ship. I dont like the fact that i like Button as i want to hate him as some parts of me do... :( ?!?!?! But its good to see the guy who has stuck with that team/people through the little bit of good but mostly bad get a result.
Will be interesting how close it is between Rubens and Button...but a strong tip that either the other teams will quickly catch up or a sneakign suspicion the Diffuser 3 will be banned as a result of Renault and Ferrari complaints about how they approached the FIA and were told not to continue their work on similar designs as they were deemed illegal
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
