Hey all.
So I've got a completely stock r33 s2, and want to build it up as a bit of a sleeper. Really stock looking on the outside, but with a bit of a punch under the bonnet. Nothing too crazy, maybe would like to push up to 200kw over time.
The aim of the game is to have the car 100% legal, or as legal as is humanly possible. I got a Just Jap return pipe intercooler put on which uses the standard intercooler pipes and did not require the cutting of the body etc. First mod= legal. A dyno run after the installation revealed that the car has 145kw at the wheels.
The other day I chuck a high flow k&n panel filter in the standard air box. Noticibly smoother accelleration etc. Second mod= Legal.
Now it comes time for the exhaust. The car needs to be under the legal db limit.
I bought a second hand 3 inch dump pipe from the forums, ready to bolt on.
I also bought a second hand 3 inch cat back exhaust, minus the end muffler. The system is designed to bolt up to the cat and can accomodate an aftermarket muffler, and has a flange, so that the standard muffler can be bolted on as well (for when the EPA bites you in teh ass presumably. The idea is to not get to this point however). Both of these parts appear to be mild steel, not stainless.
So now, to recap, I need a 3 inch high flow cat and an end muffler to complete the system. (If anyone is selling any of these items btw, let me know)
My question is. What sort of muffler should I have put on that will flow well, yet ensure that the system falls within the legal db limit? Please also keep in mind that I would like the muffler to look as stock as possible- I guess that rules out cannons etc.
Does anyone have any suggestions? Also, does anyone have any idea how much of an increase in power this should net me? Any tips etc, let me hear them as I am relatively new to the scene and am keen to learn.
Cheers.
https://www.sau.com.au/forums/topic/250355-building-my-exhaust/
Going 3" straight through you will be pushing it for legal db's!
Your best shot would be to talk to a good exhaust shop (some have a db meter handy), but i would recomend fitting a resinator of some sort
^^ you couldn't be more wrong. Easy to get a 3" legal. I have a 3.5" - 92dB, ended up with under 90.
And resonators do not work, so another piece of bad advice in afraid.
You need two decent sized mufflers. Simple as that.
A panel filter isn't illegal. You're using the stock airbox, that's all that matters.
So you cant use a pod filter in Australia? thats gotta suck
Australia's laws are so tight ass compared to New Zealand, I have to hand it to our 3rd world approach to things, lets me gets away with a straight through exhaust and ground clearance that turns me into a grader on any gravel road.
Our exhaust law still states that it has to be under 95db :blush:
oh i see
damn aye
in regards to the exhaust but i have a 3 inch turbo back with high flow cat and rear resonator + cannon and atm mines losing boost pressure up higher in the revs so im only pulling 170 on the dyno instead of about 200 which my tuner reakons i should be seeing
so yeh I'll have to see if its the exhaust doing this but i suspect its the problem
boost is on the intake side, you cannot loose boost from an exhaust, as boost does not exist on the exhaust side
I think the poster about losing boost wasn't referring to losing it out the exhaust, more so eluding to the fact the exhaust might be a large restriction causing a drop in flow, causing a loss of boost.
As to a legal exhaust:
You will want a 3" exhaust, with a 3" high flow cat, a 5" bodied mid muffler, with some decent length, and then you will want as large of a rear muffler as you can fit.
I would also say to put the twin tips on the exhaust, and have them painted black.
I run a 5" mid, and a 7" end muffler (Cannon style) except they're not stainless, and not all shiney, and the whole exhaust, when looking at it from the back any more then 2 metres away, and it looks invisible, matched with a nice and quiet exhaust note, no issues there with the plod.
My mufflers are also 650 and 550mm long respectively. You want LENGTH AND DIAMETER for a good muffler. And yes, mine are both straight through and are custom built.
i had a 3inch exhuast on my 33 s2 with a hot dog as the centre muffler (needed the ground clearance)
and a full size muffler out the back and the db meter hit 89.5 on back off (wich is ur loudest figure)
and was given a certificate to state that the exhuast was legal in every way
just one thing to know....your front mount is not 'legal' in the true sense of the term...its only legal if you pass a free emisions test at the RTA in botany or penrith...
SORRY but my comments are for NSW...
Orig poster = Vic
Vic = the laws being discussed/applied here.
Can people from other states please refrain from posting about legalities if they do not know Victorian law?
All it does is confuse the issue for people reading at present, and then later on if they search and find this thread.
R31, It'd be handy if we actually knew the person was from vic.
Nothing in the post states location, and the only way we can assume he's in Vic, is being a Vic club member, and hey, they could have moved or anything since becoming a member.
Maybe get the board admin to show everyones state at least...
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
