I though it was about time i put something up here about my car.
It started out as a standard GTS4 with only a cat back zorst imported a few month before i brought it in early 2005. first mods were front mount and a set of chrome 18's
I drove around with the car like this for a year or so with no other major mods just a dump pipe, front pipe and a bleed valve pushing out about 160rwkw.
In early 2007 i noticed that my car started to idle lumpy, did a comp test on the motor and found that i had nothing in piston 6. So i decided to go all out and chuck in a Rb26. this is the piston from the rb20
I managed to find a R33 rb26 with 80,000k's with gearbox from Japanese motorsport, i also got some coilovers, strut braces, stainless front pipes and 32 gtr brakes. I also got a Power-FC D-Jectro all installed by Tilbrook Auto & Dyno, the car was tuned by Martin Donnon and made 230rwkw.
Not long after that i got my new plates and earlyer this year i brought a set of 18x8 1/2" Drift teks.
I have now upgraded to R34 GTR rims painted the same gold as the Drift teks and i also brought a GTR interior.
I have now also fitted a GTR bonnet and grill. My next major mods are a set of Garett GT2860-5's, HKS dumps, Nismo pump and Sard 700cc injectors which i hope to have installed in the next week or 2, when there on and tuned i'll post of the dyno sheet, it should be around the 300rwkw mark :cheers:
Edited by DSTROY
https://www.sau.com.au/forums/topic/250585-r32-gts4-with-rb26/
  • Replies 46
Amazing work!! love the engine colour, did you choose that or did it come with it?
I painted it myself before it went in, its just spay can stuff with a clear coat, colour is Cyan Metalic you can get if from Super Cheap.
Damn this thing is awesome, a Sleeper and a half!
You couldn't even tell, unless you can recognise the exhaust note and you probley freak the crap out off ppl trying to drag you off at the light.
BTW you said you have an APexi Power-FC D-Jectro installed, but I see you still got the air flow metres in one of the pics... I thought you did not need air flow metres with the D-Jectro..?
is your gtr bonnet Black as well? looks gunmetal to me
Yeah it is Gunmetal, will get it painted when i get some other bits and pieces done, just dont have the funds atm.
Make sure to post up your dyno result in the forced induction sticky, i'd like to compare against mine as we are using almost exactly the same parts.. 'cept for the d'jetro.
will do mate.
The air flow meters are there to keep the street legal look, but they have had all there insides removed to increase flow.
Here's the dyno graph :)
This is my latest mod to the car, cold air box. Helps keep the hot air out and it also hides my boost controller solenoid :P
I also went out and brought this little kit the other day, just need to find the time to put it on.
  • 3 weeks later...
so.. where does the air go? I can't see any venting to allow flow through so does that mean that it will just be a dead pocket of air around the cooler or am I missing something? Other than that it looks very nice, trying to figure out where and how to mount one in my car.
I have got hold of a R33 front left inner guard that i will cut the vent out of and rivet it behind my cooler :domokun: i just ran out of time.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
