Was looking at these not long ago, specifically the S258. What stopped me was the physical size of the unit compared to a GT3076R. Aside from that these turbos sounds quite exciting. Would be a good alternative if purchasing direct from the states with a favourable exchange rate.
The only Aus distributer I could find was http://www.turbotech.com.au/sc4/borg-warner/ be prepared to pay more than a Garret though :(
Edited by MintR33
b
gt4088 vs s374 borg warner... lol.
funny how the big one comes on the same and makes 115hp more..
That just not possible!! It's bush bearing diesel "old tech", costs much less, and can be rebuilt for cheap! There's no way it can be better than a garret!! :D
Edited by Cjmartz2k
Just to clarify I was being sarcastic--I run a Holset which is a close cousin to the Borg-Warners and was catching a bunch of flak from people basically saying if it wasn't a Garrett GT series, it was crap. These B-W's, especially with the extended tip technologies do some amazing things.
Hmmm thats kinda funny seeing is my GT series turbo didnt come anywhere close to my S366. i broke traction ONCE on the dyno with my GT turbo, and it was only at 8800rpms, with my S366 anything from vtec on up is almost nothing but wheelspin, and yes im on drag radials, i just went and bought larger ones this week so i can put my car back on the dyno
The S366 made it very clear to me that my 35R was a joke
From the second comparison link given.
just something trent (uras) mentioned in a thread a lil while back...
not really sure why, hadn't really ever thought about it
yea i read this in High performance imports magazine. they say something like drag tyres are the last things you want to run on a dyno, use cheap hard low profile tyres supposedly.
im just saying what i have read though so dont flame me.
as for borg-warners, i have been hunting and all of them on ebayUS are super exspensive compared to the holsets, there is a hx40w (holset) on ebay atm for like $350 and they flow like crazy, just ask CJ.
havent been able to find any suppliers in Aus for borgs and holset are super exspensive if you buy em here.
cheers
Gezza
Yup, no-ones saying there cheap. They're a dedicated performance turbo with a range of housings available. They are marketed against Garrett. The majority of Holsets are oem for diesel applications.
Yeah, that's the great thing with holsets. I'd say the HX series of holsets is pretty much on par with the non-extended tip versions of Borg-Warner's performance wise. It's just that they are so damn cheap (at least if you can get them from american ebay). One of the downsides with them is you have to spend a little time hunting up the correct sized ex housing sometimes. You can't just order them with the size you want for cheap. They are a viable cheap alternative to garret's.
One thing to note with the comparo's above, they were both single scroll turbo's, but most of the BW's, and almost all of the holset's I have seen are twin scroll which really help's with spool times.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
