  • Replies 181
NEW ENTRY FORM
MUCH EASIER TO UNDERSTAND TOO
http://members.iinet.net.au/~gavingriffith...tryform2010.pdf
Just to be aware folks, there was a typo which I did not spot until late last night on the original form that I was given to begin redesigning it from (You can blame me for any problems) If you look, the two images from my photobucket account above that Matty has linked to show the wrong end date. This has been corrected in the PDF link but I will not be able to do anything about the photobucket ones until tonight when I get home. Any entries coming in from the JPG images with and end date of the 14th will still be accepted but I suggest using the PDF link, it will print more clearly in any case.
There are also some pricing differences in there in the way things are grouped together. Nothing is more expensive than before and most "Packs" are a couple of dollars cheaper than the previous prices combined. That is to say it is slightly cheaper to enter with a full event pack than it is to enter the sprint and the show and shine and to buy a dinner ticket and promo pack seperately.
Paul.
EDIT, SemislickR32. No, if you have entered on the old form you do not need to enter again.
Edited by Blue
OK, photobucket fixed. I re uploaded them with the same file names so the forms are still in Matty's post. This entry form is now uploaded on the Skyline nationals website so people should be seeing the same form from any current place to get them.
I suggest using the form direct from the nationals website so that if any further changes are made you get the current form. I do not expect the form to change between now and the event though.
http://skylinenationals.com/2010_Skyline_N..._form-final.pdf
Sent (and paid ) my forms off 4 months ago and emailed again 3 weeks ago and no reply :mad:
who did you email? I sent one through today and got a reply 3 hours later. Email was sent to : [email protected] (via the skylines national website)
Just to confirm, any model vehicle is welcome to enter the super sprint at Mallala. There is also 4 different groups, standard non turbo, standard turbo, modified turbo and 100% track car group etc.
Ryan
Ryan
They have the cash , just to slack to send a reply
So what is the likely timetable and format for the track day? Time attack or racing
The exact format of the day is being settled but things should start to happen on the track itself by 10:00 with scrutineering starting at your normal sort of 08:20. Supp regs and formal sprint entry forms should be gong out very shortly to those who have already entered the sprint on the main nationals entry form.
The day will be a multi car supersprint format against the clock, not racing. Racing would exclude almost everyone who would want to enter as that would require a C level license not an L2S.
OK, I should have Rbware sorted now, if anyone else has missed out on an entry confirmation could they PM me about it so I can follow it up?
REV-031, if you want to do it, just do it! There is no pressure at this type of event to go any harder than you want to, so if you just want to cruise around at a moderate pace and get a taste for it then there is nothing to stop you doing that.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
