+1 Dave. So sick of the "how do I raise my boost for free" shit threads and people wanting mega power on a shoestring budget lately!
How's your setup coming along for power cruise? Give us some good news!!!
Matching turbos and supporting mods to achive a practial/streetable Car has nothing to do with "raising boost for free" or even a budget for that matter, Our cars are money pits No matter which route you choose, Just aslong as you have fun with it
Practical street car talk is over here;
http://www.skylinesaustralia.com/forums/topic/236467-definitive-guide-to-building-300-330awkw-gt-r/
Enjoy! :) (Not being rude, but anyone in here with 400kw doesn't really give a shit about practicality)
Getting some stuff done at Speedfab, should be back at JEM by the end of the week to get all bolted up.
Cutting it fine as usual. :rolleyes:
Got to admit, you're consistent haha
Havnt heard of speed fab before-tell us a bit about them?
His name is Rob, PJ put me onto him. Did all of his metal fab stuff.
He made a manifold for a customer at JEM. Top notch stuff, so he made my new one, shroud for thermo, a bit of pipe work.
So yeh, fingers crossed it all comes together in the next week or 2. It will be a car to keep your ears open for at Powercruise :)
I would just like to have some more time behind the wheel in between breakages. :cheers:
finally cracked the 400 mark
r33 gtr 1995
rb26
engine
honed/bored 0.20# , acid dipped all usual machining done ect
shot peened n1 rods with enlarged big end bearings , crank balanced re nitrided and oversized 0.60 acl race bearings
arias 0.20 over pistons , acl piston rings
tomei oil restrictor
tomei sump bafffle/trap doors
N1 water pump ,
s oil pump
genuine nissan gasket set throughout
cossworth drag series 1.5mm metal head gasket
head reconditioned with porting on exhaust side , hks 264 cams greddy adjustable cam gears
arp head stud kit
driveline
Very rare Autogallery yokohama 1-5 H/D set with double cone syncro's , redline shockproof oil
Os giken pro series twin plate push type clutch
Vspec rear active lsd diff
Turbo/exhaust/intake
Trust greddy t517z turbos with 10cm housings
standard manifolds match ported
hks non turbulent dump pipes
custom twin 3inch y pipes with 100cfm race cats y pipes individualy run to centre of car and then merge into 3.5inch exhaust with highflow muffler and 5 inch tip
apexi hard pipe intake kit with twin z32 afm
electronics/ignition/fuel
apexi power fc , with hand controller
blitz 4 stage electronic boost controller
bosch single 044 mounted intank
injector dynamics 1000cc injectors with convertors t fit 10.5mm standard rail
turbosmart adjustable fuel pressure reg
splitfire coilpacks
hks twin spark DLI amplifier
low compression engine tested 128- 132 across all 6 due to 1.5mm h/g , current power 405kw@wheels on mainline dyno at 23psi fuel pump is probably near its limits but this is plenty for me!!
Good result man! No spark issues with the Twin Spark?
Prob a bit more left in it with a little more boost!
by installing your hks twin spark and splitfires and adding 3psi gained 55 kw atw f*kkn redicolous gains lol , must have been missfiring somethiung fierce before!!
r33 gtr 1995
rb26
engine
N1 water pump ,
s oil pump
arp head stud kit
driveline
splitfire coilpacks
How do you find the gearbox? Have you driven the Os Giken one to compare it too?
That should be in the title. A disclaimer like "if you're after response, do not click this thread"
LOL ye not like people are running 540ci motors.
Some results in here are pretty damn decent for the power none the less.
Its all about the number nismoid. This thread isnt about response haha
It should be. Why would you not want your cake and eat it too?
Noel makes 24psi by about 3500rpm from memory and he doesn't even have the VCT back on it yet. Correct turbo selection and head setup and you can make 550-600hp and still have good response
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
