I must be missing something, whats the relevance to this discussion Marko?
I am making a statement that its a nice car, is that not allowed on sau?
about the same relevance as that 300,000 word 20 year old sig quote
hmmmm...i will amend my sig if its that much of an eyesore
Thought that may be the case!
enough with the bait! give it a rest
Always a bit sceptical when theres no corrections on a dyno dynamics graph for all we know that graph could be stock turbos with 200 degrees of intake compensation.. Before xmas my car made 492rwkw on e85 and 26psi on a pretty hot day with 28degrees AirTemp 49 degrees InletTemp compensation worked in the figure i thought nice not much to go till 500 now. After having a few problems we stopped tuning for the day, 2 days later went to another dyno, tune unchanged made 460rwkw i was like :mad:
Anyway dynos tell porkies we need more mph on the 1/4 in this thread.. :cheers:
There was a full thread on the car specs if you want to know more - rb29 was in the title IIRC.
"RB29 wow". Great thread, and that graph is pure car porn.
Hey question for you guys.. Im currently building my engine, and a thought crossed my mind.. The gtx3076r's compressor map shows it can flow around 65lbs/min of air at ~29psi. Could this translate into a hopeful ~530 - 550rwhp? Or ~400rwkw? I mean, could it be done for sake of argument..
The housing configuration i figured would be a 1.06 T4, most likely divided and mated to a twin scroll manifold.
Any thoughts guys? :)
I wouldn't, not unless you've seen anyone push one that hard and make that much power on a dyno type that gives results which reads in the area you aim to reach that power on. You certainly won't be getting that power from one on pump gas on any dyno, E85 or something similar would be a must.
400kw should be achieveable on E85 with a GTX3076R at least on a hub dyno, actually even potentially with a run of the mill GT3076R.
I thought the same thing, the GTX3076 compressor flows nearly 5 lbs more than the GT35 on paper so 400atw should be theoretically possible with enough boost.
Was definately thinking the e85 route aswell. IIRC, some of the supra guys have them running 26psi, so i figure the odd jump to 29psi would be ok. And because of the 1.06a/r, EGT temps *should* be fairly acceptable.. I think?
Wouldnt the gt3076 be out of its ideal efficiency? I mean, i havent seen one go past ~24psi, but then again i havent looked for that exact figure..
My build should be done around september, so might push it to 29psi to see if its achievable.. For science-sake :)
Scotty, glad to see im not the only one! :D i know the gtx are marginally slower coming onto boost, but i figure the divided housing mated to a twin scroll mani should bring it back to bee's dick of difference.
Thanks for the input gents! :D
The normal GT3076Rs have been pushed up past that before and made good power, but yeah they are definitely pushing shxt up a hill. I reckon the gun choice for what you're looking at doing would be a FP GT3076RHTA personally.... have a look into those while you're considering it.
They are claimed as 59lb/min, which sounds underwhelming compared to the GTX but bare in mind the maximum flow is rated to whatever flow efficiency the company decide to use as a cut-off and isn't an absolute - and also Garrett themselves have ultimately said the 77mm compressor used on the GTX3076R isn't suited to the GT30 hotside by putting it on the GTX3576R, the extra flow is argueably redundant on the GT30 turbine.
I think the HTA76 wheel is basically the ultimate compressor for a GT30 turbine, the most flow you could put through that turbine with better response than a normal 56trim GT3076R wheel.
Problem with ramming so much boost etc, what happens if you get a slightly average batch of fuel?
There is really not enough room for error running uncontrolled fuels in street cars.
Mine is lasting well so far, haven't had any bad batches of Caltex yet either according to the wideband anyway. I did hear it pinking once on cruise one of the hot days we had, but its running 18:1 there for economy atm. >_<
Im not scared about the little VQ, seen many stock VQ30det's pushing big numbers (400-450kw) and the VQ25det runs the same rods, the main worry is the auto. Either way, I have spare engines and a trans here.
I doubt 400 is attainable with the auto, (I would be happy with 350) but a built RB with a GTX3076 would sh*t it in. I will check out the HTA76 further Lithium but I think the compressor housing is a little too big. Does it still run the Garrett rear?
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
