We only used two sets, both times the car wouldn't start. We had to run them through the injector bath twice before they came up good.
We had the same with a Bosch injector once also. That's why we clean all injectors before use now. They aren't bad injectors. Not a single injector on this planet can be cleaned and flowed, then sit for a month and still have its company guarantee its perfection.
We've never had lean out issues with the pencil type 1600's.
Any time we've had an injector issue with a Bosch injector (ID's included) they were fixed with a clean so we never had to return any.
Yep that's correct ID had a issue with a certin type of after flow matching lube that caused the batch problems. I know FIC and ID pulled the 1600's from there lineup cause of the leaning issue..
Dan, where did you get the ID"s from? plenty of people sell bog standard bosch ones as ID's
The ID's were purchased directly from Injector dynamics both times by my customers. They came with the ID spec and flow sheet also.
There are also no difference between the ID's and the Bosch injectors except for the fact ID apparently dead time test their injectors and Bosch don't.
Bosch are still flow matched and flow the same.
I don't see the point in paying extra for the same product. We have seen the spray pattern on both and cannot tell the difference
Just gasket on with nothing ye? Im sorry i know its a stupid question but its my first time
Yep, the gasket provided is all you need.
And I disagree with Marko, there are stupid questions....but yours was not one of them. I just couldn't resist the temptation to be idiotic
There are stupid Q's OK but it would even stupider to put that engine together then realise wtf I should have asked about that sealer (definitely not taking a dig at u daniel after helping me with that nugget white gtr u inspected for me at no fee last year :))
Anyone in here know of a place to get the push in fittings for RB26 cam covers with a 90 degree outlet?
NOT a straight then add a Speedflow 90 degree bend - that wont fit. Needs to be the same fitting that goes into the cam cover that's got the bend in it
I just want to know a couple things from you 400kw guys i wana know,
What sumps you guys are using if in melb where u got it from size cost and if from out of melb cost of freight
Can the std intake piping and cooler support 400kw ? Coz i wana try keep it for now cant afford it,
Std exhaust manifold port matched to gasket will it flow 400?
Cheers
Cheers
Standard intake piping as in the pipes from airbox to turbo's and the 'twin turbo pipe'? If so then yes
Exhaust manifolds are a yes also.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
