Thanks that would be great!
I'd be keen to hear more about lowering the engine. I know several RB30's have been put in at stockish heights, but everyone seems to do it differently. There's a market for bolt in mount kits, so everything needed to install RB30 to R32GTR in one package.
that guy simon has the worlds best kept secret on lowering the engine but he won't let the cat out of the bag
.I have 1 theory which I've discussed with another mechanic and would work
I heard of a trick using rb20 engine mounts which lowers it 10-15mm. Though dont know how accurate that is as I havent done it myself.
How much lower would the engine need to sit in order for the timing cover to not hit the bonnet bracing? Would 20mm drop be enough?
I recently did a 26/30 for someone. It required an 8mm drop, bonnet support cut out towards the front and the twin turbo 'badge' shaved off the twin turbo pipe to make it smooth.
With all that, it only just touches by a whisper.
With a standard bonnet I'd say 25mm would see it clear with no other changes.
I'm fairly sure RB20 mounts are the same height as GTR but I could be wrong. The other problem with lowering the engine in the subframe is the clearance between the sump and the subframe is only about 15mm at best from factory. You could possibly go 10mm of that but I reckon driveshaft clearances would have to be considered if you did
exactly what i did to mine - cut the bonnet brace above the front cams, took off the twin turbo badge & milled off the boss for the badge.
funnily though, i had to run the bonnet without the insulation as this was starting to rub the paint off my newly painted covers. that is how tight it was under there!
I was thinking if you could achieve say half inch of lowering engine towards sub frame via engine mount mods and then lowering sub frame half inch off chassis rail then you would be pretty damn close and both of those things are very straight forward and have probably been done before. But as you said you would need to look at drive shaft clearances and angles.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
