Here's what Speedflow have for the job if no one makes them as push in; (excuse the shitty picture)
If you remove the swivel from the bottom that will leave a smooth surface and if your lucky enough it will fit straight in, if not you could make a sleeve
you would have to measure it all and see
but something to think about
I think I found the solution, they have a fitting similar in a way to what you've said. I've been meaning to swing by MSCN for the last few days but haven't had the time.
Hows your R34 build? Texi ready? (secretly hoping, I love watching you belt the shit out of the courses at Texi haha)
I have a little over 400Kw ATW, .................. It's somewhere around 670Kw at all four wheels,
understatement of the year? hahahah lol :D
That is a f*ck load of power... did you go an AMS kit for that?
R35s are just another level, and ppl bag them out lol because they don't look tough or they don't have a gear stick (not a real drivers car because there is no clutch).
U can't match them. Case closed. I'm buying one soon :)
Yep, AMS Alpha 12 kit. Minimum boost possible is 23psi. In the states they have the same kit running 30+ psi and they're pushing out around 970Kw at the wheels, crazy stuff.
Well that's it... I'm out. I may as well pack my stuff up and go home.
Jesus.. 675awkw.... Pfff!
There is no point continuing..
Hey Ash, nope, it's going in to have a new Syvecs ECU installed next week. Finally we'll be able to tame this thing !! Do a search on YouTube for Syvecs in the R35. Awesome stuff, boost off the line, anti lag etc etc. Time to ramp it up.
You'd be happy to hear the G55 is in getting a work over at the moment, adding another 100Hp to it.....
:thumbsup:
Sounds damn near amazing!
And lol @ you working the Merc, that's awesome :D
Not my car, but the guy who owns this car isn't on this forum - but is happy with the results to be shared... and I think it would an interesting setup to throw into this mix.
R32 GTR
Series 2 Nissan/Holden VL Turbo RB30 Block
RB26 Head with Carl Ruiterman Port work/Bowl work
6 Throttle Bodies Enlarged with new XS Seals
Kelford 280deg 10.55mm Cams
Kelford H/D Valve Springs
Tomei Cam Gears
Full Nitto Gasket Set with 1.2mm Head Gasket
Nitto High Volume Oil Pump
Nissan N1 Water Pump
Greddy Plenum, port matched
HKS twin entry fuel rail
ID1000 Injectors
Sard FPR
Venolia Forged Pistons 8.5:1 C/R
Argo I-Beam Rods
Balanced and Cryoed Factory RB30 Crank
Nismo Big End/Crank shells
Ross Metal Jacket Crank Balancer
Custom Billet Mains Set with RB30 Sump Adaptor
RIPS Extended Sump with extra baffling
RIPS Knock Sensor Brackets
Nismo Oil Cooler Block
Refurbished Altenator
Underdrive waterpump and Altenator pulleys
GTS-4 Diff Ratios
Sinco Customs Steampipe Twin Scroll Manifold (No wastegate pipes)
Borg Warner EFR 8374 .92a/r Twin Scroll T4 with Internal Wastegate
440kw @ 4 hubs on 20psi running BP98
The car made over 460kw in tuning, but as they started going higher in boost it started becoming more unstable - so these results are "dialled back" until they can get a better handle on the boost control and then it will be going back on the dyno.
LOL, maybe this thread should only be RB power?
VR38 owners have it so good, they'll never have to replace a bearing!
why do u say a vr38 won't need replacement bearings? I know they are amazing but are they really that good :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
