480kw on vp 109 and dash 5s @ 23psi, BACKED UP with repeated 140+mph runs. It can be done, just not by many :D
Mark32 being on powerplus rated at 108 would be pretty damn close to vp race fuel, i dont see why every one is getting their panties in a knot. Edited by linkems
I don't understand what the issue is. e85, increasing boost later in the rpm range, and 'at the limit' tuning probably explain the nice graph
20psi @ 4700rpm sounds very good, but reasonable
700Nm @ 5000 rpm sounds very good, but reasonable
nobody else even talks about, let alone posts graphs, about increasing boost with rpm. that's probably the main reason for the high peak power.
Finally someone with some backed up proof.
How much does your car weigh? I suspect you have more than 480kw
the specs from that video:
HKS 2,8l stroker kit + twin GT2860-5 + nismo intake plenum + greddy 264 cams + 1000cc RC injectors + Apexi D-Jetro + Almasi tuning
the scale on the torque curve looks wrong, but the power curve looks accurate
http://www.gtrpwr.co...thread.php?t=62
Edited by black bnr32
Yeah most people don't, but sometimes it's gotta be done because everyone else around then expects it to be "the norm"... And then we end up with more and more threads like "why am i down on power", when in actual fact they are perfectly fine... They are just expecting something that's not reasonable and trying to explain this to such users can be about as productive as belting ones head against a wall (similar to telling the GTX/500rwkw person that it was not possible, but we were all haters :/)
And for the record, there are no mini-me's running around that i know of :ph34r:
If you think thats BS, i know one person who got "498rwkw" out of -5's on PUMP and when i asked him to back it up with MPH he said its an inaccurate way to calculate power! the fark lol.
There is a guy in NZ that claims mid 500kw on pump on GT2860Rs who is a fairly respected track racer etc, which sounds like crap - even on a high reading dyno. The trap speed argument has come up but he has no interest in drag racing, conveniently.
We have no interest in believing him then
Dumb comment old boy
Maybe this engine is just more efficient than all the others using the same turbos hence the higher power....
And saying that the 1/4 is the real dyno works to a degree if you have traction. But what if your running street tyres and no traction at all like Marks 32 could be wheel spinning across the line in 5th gear and still run under 120mph....
But we also have nice clean air down here in Tassie....
Edited by WHITER33GTS-T
He also has a 2.8 maybe even a 3.0 bottom end.
Different ball game to the normal 2.6
Yet another keyboard god that knows everything from behind the computer screen just ask him....
Try geting some real world experience old boy instead of just reading the interwebs then thinking your an expert on everything
The clean air must help a shit-load Rob, and you know better that anyone a lot of cars have been on that dyno and he's not the sort of bloke to produce stupid unrealistic dyno results.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
