For my run, that calculator is out by 100kw.
What happened to the nitto engine in mercurys gtr?
I heard a few different stories, one was bent rods in 1 and 6 after running on the dyno with a headgasket leak.
This is what i heard to. Also heard it happened before that 1072hp run :wacko: .
Also heard there is a nitto rb32 being built for when the current bottom end gives way.
I'm not really an expert on the subject but if you take out an auto and put in a manual, aren't you going to make more HP at the wheels?
This would also coincide with your higher trap speed
of course..lol, but doesn't the moroso calculator work out weight shifted power at the "engine"?, engine power will still be the same
rwhp will be different, in my old car it would make another 50-60rwhp i would have thought manual, hence me asking the question..
guessing it doesnt account for that
cheers
darren
Marko ur time and mph is very impressive for that power
My best is 11.30 @ 127.5mph with 340rwkw
And my 32 Gtr got weighed during engineering process and was 1620kg i think (full interior, spare wheel, etc)
With reduced weight it is closer to my power but still 70kw over the mark
Is it possible you actually had 500hp? And half a tank of fuel? Can you send me a PM with your setup so I can see what sort of power you should/would make?
my cat isn't too healthy at the moment unfortunately :( - i'm not going de-cat, so should i just get one of those 100cell 5" venom ones? haven't bought a cat since my last GT-T and that was years ago... just some little 3" catco one....
some SAU searching brings up Venom a lot but some uber german brand called HJS gets a bit of a mention...
don't know if there have been any major cat improvements over the years, bit out of the loop with these things....
EDIT: forgot about the ballistic cats... i do remember those from a while back
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
