I used a heat gun to slightly heat the yellow section then just flicked it off with a screw driver it should pop off does a little bit of force. What your left with is the same metal part showing on the standard 26 injector in the picture. You then need the new pintle cap thats suits the indy injector which just pushes on then it will suit the standard rubber on the inlet manifold... Hope that makes sense
Makes sense, thanks. I've emailed injectors online regarding the 11mm caps, see how we go.
I grabbed a 14mm rail from mrparts for the others considering machining jap rails. Quality looks on par with the hks rail it's replacing.
highest i have seen so far is 427 out of a 0.82 on E85. (NYTSKY's car)
My evo isn't far off that with a .63 and vp109 :devil:
cosworth 2.2 stroker kit billet crank option
full port polish 1mm oversized valves big cams standard intake plenum and throttle body
6 boost manifold tial 44mm standard off the shelve .63 GT35 from garrett 3inch dump pipe 3 inch exhaust
plazmaman cooler
2x 044 2x -8 feeds to sard rail 1000cc inj -8 return via PFI reg
29psi boost
any news on how the new head performs?
Sorry mate, i was a bit premature. still building the new fuel systam atm. If all goes according to garp we should be on the rollers on thursday or friday.
Got a lot of conflicting info on fuel line compatibility with e85 so to be on the safe side we are changing out everything except the fuel tank.
Noel's new fuel system includes:
2 x Pierburg fuel pumps flowing 6.5L/min at 5bar
1 x 4L surge tank
2 x cleanable fuel filters
-6 hose in boot and complete underbody hard line mounting in -6 fuel line. 1 line for each pump
6 x New Series Indy Blue injectors ( not the old style ones )
1 x Tomei fuel rail and a whole bunch of fittings that Noel cried about having to buy again :D
1 x 4L surge tank
lol the old girl :D
Whats the vapour odour like?
Nice big tank
Still got rego?
Certainly does. A surge tank is only an extension of the factory fuel system. We have engineers approval on that and a blue plate just in case :D
lol the old girl :D
I'll tell you when we start it :(
lol the old girl :D
Watch it pup
Dan - where do you get the Pimps from?
Edit - oh wait, pumps* lol
But I am sure Noel is a Pimp, his car is way too nice for him to have a legit job :laugh:
Pimp daddy pumps from either ERD or EFI Zeb.
Me thinks they are going to become very popular now that e85 is becoming more available.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
