do all jap cars have 180km/h speed limiters eg: nm35 axis , and how are they removed, do jaycar make a kit, they make about everything else ???? :cool:
No just cars intended for the Japanese domestic market. In manuals you just cut the appropriate wire but for autos you need a device such as my GReddy Speed Limiter Cut Controller ($160 roughly) which will do the job. Jaycar don't appear to make one. You can get the speed limit removed with some major re-chips or of course with an aftermarket computer.
If you are going to install a piggyback ECU, I believe that the eManage Ultimate can override it.
Did you end up getting that white Axis Alan?
still , in the pipeline at the moment cam , fingers crossed , waiting on some shares i've cashed in, got out on financial advise it was going to crash, down to the solicitors now , maybe a couple of weeks , then i'll have a definate ?????? :P
hey mate, what is this "appropriate wire" you speak of? is it hard to find? has anyone on here with a manual sII done it before???????? please please please :P :P :rofl: ill be your best friend if you tell me how
P.s. it would really shit my mate off that has a 33 coupe :/
hey mate, what is this "appropriate wire" you speak of? is it hard to find? has anyone on here with a manual sII done it before???????? please please please :(:(:( ill be your best friend if you tell me how
P.s. it would really shit my mate off that has a 33 coupe :D
Well your mate's 33 coupe is probably wire 53 but I'm sure a search in the Skyline section will confirm that. I had a quick look at the pinout diagram for Stageas (you'll find it in the DIY section under ECU) and the most likely suspect is the wire on pin 29 which is where my greddy speed cut thingy is connected. In my car I hit a wall at 180 (it could vary according to how accurate your spedo is, what size wheels and tyres etc) but since putting the whatsit on the ECU i have had 180 - 190 at the Taupo A! GP track and just over 190 at Manfield. I was looking forward to Pukekohe next month where i should have been able to get well over 220 on the back straight but unfortunately my car is no more. Have to wait til i build my next one.
i've taken mine over 180kmph (the needle just kept going)
and i dont seem to have anything attached to my ecu :(
You and me both.
I guess that the needle would have hit 195kph if there were numbers that far.
I do know that my speedo shows 7kph high out due to 18's, but could the original speedo be out 10kph?
I think that only applies to maybe R33s or newer, I know the r32 autos still work with the wire cut, 52 or 53 is the one :D green and yellow?
you hit a wall at 180 ? phsyically ? or with the computers speedo cut ...
yeah, as soon as mine used to touch the dial, it used to pull back the fuel and start shuddering like a son of a b*tch
Thanks mate! and nah i wont be worrying about my mates 33, although he will start asking questions if we do a midnight run out to the beaches and i fly past him at 200+ lol :D
wire 29 you reckon hey? well ill check it out on the ecu thing anyways,
Cheers
hey mate, what is this "appropriate wire" you speak of? is it hard to find? has anyone on here with a manual sII done it before???????? please please please :(:P:( ill be your best friend if you tell me how
P.s. it would really shit my mate off that has a 33 coupe :)
powerfc cuts it nicely.
I dont quiet get why people want to remove the speed cut on their cars.....
180 is plenty fast enough as it is(havnt even hid speed cut in mine) . Plus its bad to push it that hard and spin out top gear.
Isnt it all about how fast and how much it throws you back into your seat...
Removing speed cut is not a necessity for the road (unless you are in Germany) but it does not do any harm - you can do 180 in third and in fourth 200 is not really revving hard. BTW I don't suggest trying these speeds on public roads and not anywhere if you haven't done some basic improvements to your suspension and wheel alignment - the standard setup could have you struggling to keep it on the road at illegal speeds. It is a necessity for track days unless you like being passed by slower cars that don't have speed limiters.
thats why i want the speed limiter removed for track days , plus i've had vast experience with advanced driver training in the past so im im quite capable at handling high speed driving , NOT IN ANYWAY WOULD I CONDONE DRIVING FASTER THAN THE RECOMENDED SPEEDS ON OUR PRISTINE ROADS !!!! ;)
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
