  • Replies 40
hehe eric my wheels will be that colour in about a month :P hmmmm urs have the center caps... im missing 2 of mine... i know where u park too... hmmmmmmmm ;)
thinking about rolling the rears but it will crack the paint and look crap.
https://www.sau.com.au/forums/topic/25264-predator/#findComment-537606
oh yeah Al... most likely the next calder night providing its not raining... at one stage someone else is going to have to drive the soarer cause i dont think my gf will do it as hard as it can go... so might have to get someone to drive it :P
https://www.sau.com.au/forums/topic/25264-predator/#findComment-537610
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
