Hey all im fairly new to the skyline world, bought an R32 gtst M spec series 2 with a few tastefull mods including
HKS 25/30 ball bearing
GTR injectors
Ballast resistors
Bosch 044 in tank fuel pump
Hybrid front mount
full 3 inch turbo back exhaust
Turbosmart manual boost tee
ECU tuned by mines
Supposedly done 220rwkw on 16psi on dyno but never saw the sheet for proof
Atm running 12 - 14 psi daily comes on full boost at 4000rpm and pulls like a train :D
Just wondering whats next? inlet or exhaust manifold or should I save for the RB25DET?
Every opinion welcome
get a z32 afm and have it the ecu remapped. run 17psi and you will have a nice quick r32. also replace that boost controller with a turbotech boost controller for faster spool and better boost holding.
you could also get cam gears and have them set up.
power fc.... or nistune asap
unless the mines ecu was mapped for EXACTLY those mods then you are playing a very dangerous game!
i'd also go an ebc for faster and better boost holding
+1 on the ebc too
remap that ECU, I believe that mines ecu is tuned for japanese fuel, it won't do any good on our crappy 98ron fuel and get a proper boost controller, that turbosmart thingo is only good for boost spikes.
If you're on a budget go buy a turbotech ball bearing valve, and sell that turbosmart junk and make a profit.
the mines ecu will be tuned for whatever mods were on the car when in japan... and it will be a really old tune aswell...
run low boost... then get a real ecu or a tune :P
2530 turbo gets about 230 max kw so theres no point spending 1000 plus for 10 more kw.
keep the 2530, Bosch 044, Hybrid front mount, exhaust and sell the rest like GTR injectors etc and save for a RB25, unless you want to upgrade to a bigger turbo because 2530 wont get much more.
you'll get 230rwkw or so out of that setup when you get an ecu and an ebc and a tune.
dont bother with the 25 - it'll cost way more than its worth seeing as you can only pick up another 50rwkw or so on the stock bottom end anyway... an you might be buying someone else's problems....
a built engine is worth it... but then your gonna be looking at COIN
my advice...
stick with what you have... get an ecu and an ebc. get suspension (coilovers, camber, castor, pineapples, sway's) and enjoy the living hell outta it
I cant agree more!
power fc and ebc sounds like the go, the ecu it has atm must be tuned fairly rich, it blows a fair bit of black smoke when on full boost and on start up so hopefully it will be alright on 12psi.
only reason i want an rb25 is for bottom end :(
cheers for the input :)
For a cheap good option get a remap $200ish+dyno (which is almost as good as a powerfc, just can't keep an playing with it), and the turbotech boost controller is way better than the boostee, and only cost $30-$40. Should be good for a more responsive 230RWKW :P
the rb20 injectors max out at 200kw (like mine are currently). For any power above that, GTR injectors are a must and its evident with his 220kw so far.
Depending on where you live, get a turbotech bleed valve and a remap from CEF11E.
You could also get adjustable cams to improve the curve, not so much power gain but could result in a better low-midrange.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
