Guys,
My airbag light was flashing and I found the solution on the net and it worked first go on my M35.
Turn the ignition to the "on" position. Watch the airbag light closely(it will be on solid) the split second it goes off(beggining to flash) turn the ignition off, count to 5. Turn back to "on" position and do the same another 2 times.
Next time you turn it to "on" position it will blink really slowly(diagnosing) Then switch off. Next time you turn it on it will be solid and then turn off completely.
Much the same as what Iamhe wrote above, that worked for me 6 months ago but a battery replacement last week caused it to flash again. I would say this was caused by a low voltage to the controller. Lucky its an easy fix.
  • 4 months later...
Hi Guys,
my local Repco mechanic couldn't clear my flashing airbag light with his plug in gizmo.
I tried the solution above and it didn't work but did give me a repeating series of flashes which, I assume, helps with the diagnostics.
My airbag light did this after following the procedure above:
9 flashes, pause, 10 flashes, pause, solid for 2-3 secs, longer pause, repeat
Now to find out what that all means.......
need the seat replaced. already done one in a PM35. there is a airbag ram in the base of the seat and the explosive device has died.
its nothing to do with the diagnostic routine you guys are doing and in fact it renders half the system useless when in fault mode. not the sort of thing you want when you smack something at speed.
Thanks for the good news. :laugh:
Mine doesn't have the airbags in the seat so I guess its a different problem?
I figure if the reset works for a few weeks or months then its a wiring or connection fault more likely? I'm replacing the seats soon so hopefully Bride has figured out how to get around the problem.
thing is they DO NOT need bags in the seats for this fault. the ram is in the seat base. given that the youngest car (NM35) is 7 yrs and the bags/supporting devices are supposed to be done at 10 yrs most of these cars are either due to be done or about to fail.
  • 3 weeks later...
Sorry to dredge this topic up again, but my light has been flashing since I got the car so I can't be certain if something is just broken or perhaps not connected. (You'll need to hear me out..)
And, before anyone asks, here's what I have done already:
1. Checked all fuses using a multimeter
2. Tried to reset the light by the method mentioned elsewhere in this forum
3. Had my local mechanic try to reset the error codes with his computer thingy (that'll be the technical term I'm sure :starwars: )
BTW, the error codes (as displayed on the computer thingy) are:
B1161 CRD RH (OPEN) and
B1166 CRD LH (OPEN)
A short time Googling these ODB2 codes shows results from Toyota and GM products with a few anomalies.
eg. Toyota list them as: B1161 Inflatable curtain RH open circuit (84?) & B1166 Inflatable curtain LH open circuit (88?) which sounds a lot closer than GM's "B1161 = Lamp circuit failure".
Since I don't have curtain airbags, I started looking under the seats for signs of seatbelt pretensioners having been activated etc and was greeted with this (see pic):
Now I've read that yellow connectors are typically associate with airbag circuits, so could this be the "open circuit" referred to in the ODB2 error codes?
I also found a picture of under Bis-e Bee's front seat (thanks mate) and it confirms the yellow plug is connected (see other pic).
But.... my car doesn't appear to have anywhere to plug in the free connector.
Any ideas anyone?
yep yours has the same issue as most. the anti subarmine rams are gone. new seat time (x2) for you.
Is this the only option?
Any idea of the cost (they are the leather seats)?
If what you say is true and, depending on the cost, we may be waiting a while to get you to do the cruise/english conversion we spoke about the other day.....
Cheers.
Also Chris, what is the go with those connectors of mine under the seats that aren't plugged in, and look to have no where to be plugged in?
Do they have no bearing on any of this?
Can Nissan really design a car that needs the seats replaced when an airbag component fails?
My X-Trail is about the same age as the Stagea & it's never had any airbag warning lights active. Is that just a matter of time too?
All these unanswered questions.....
come for a drive through the week (call first.) and I'll take a squiz. thing that gets me though . how did it gt complied with that light on and even more so how did it get registered. that is a sizeable defect that should not have been allowed through IMO.
Cheers.
Chook on the forum is the one who can help you with the language conversion in QLD now..
Good luck sorting out the airbag light.
Cheers
Andy
I'm about 2hrs away so won't be able to drop in this week, but if I'm no closer to sorting it out when I visit for the other work I'd appreciate your input.
I think I'll explore some manuals/wiring diagrams to see what I can learn.
Re compliance/registration - I'm not sure how long the fault has been around but can only guess it happened after those things (but before I got it) as I can't see how it could have passed.
Possibly the importer reset the system so that it wasn't flashing during the "important" steps of compliancing etc.
Mine started to flash again, reset it Thursday night and then on my way to work Friday morning, hit boost and it went off again.
Reset it last night so hopefully it won't happen again for a few months, really hoping it doesn't become a too frequent event.
My error code was the same as Scott's (from memory) something about RHS Cord or something.
You may be right but hard to tell since the guy we bought it from isn't saying too much. All I know now is that it can't be reset via the "proper" ODB2 gadget at the workshop nor have I been successful with the DIY method.
I hope you don't have continuous problems with yours as it wears thin real quick. Interesting issue with yours re. it being related to the boost. I wonder what the connection could be there...
I think when I find out what these unplugged yellow connectors are for I'll be a whole lot closer to solving it.
the 4hour drive will answer your questions you know. there is really no point posting it here when no one has the correct tools to fix the thing and further to that I know what I'm looking for when I see the car. most are going to tell you to go nuts with the door swtich which in your case is not going to help.
as it sits now with your car: SRS system offline therefore car unroadworthy therefore its NOT insured if you smack something.
bisebee,
yours is a similar issue. seat ram is farked. common on the V series cars from 2001-2004.
Cheers
Andy
he's already involved in this one:)
Hi Chris, I'll give a call to tee up a time as soon as I can get half a day free. Could be a week or two though.
Thanks for your help.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
