I don't know why people even bother with them? If they can bullshit you with reasons why they can't insure you, what makes you think its going to be even better with a claim?
I know Wayne got f**ked when someone reversed into him. They ruined the side indicators on the quarter panels then when his headlight got moisture in it they blamed it on age, even though the other side was fine nor was it leaking water into it before the accident. So they refused to fix it. Bullshit.
good old insurance, I moved closer to town (the dirty south = ghetto ) and it doubled the monthly cost. had to nego to get it lowered to only 20.00 a month more then aldinga beach
and value has fallen by 600 bucks without warning. but agreed value is still really high, 29,400. (shannons)
end rant. :)
time to move again...lol
someone needs to create an insurance company that does something along the lines of e.g. you only do 5,000kms a year on your car so your insurance only costs xx amount. As oposed to you have to pay a full premium every year.. it's crazy there is only a really small amount of insurance companies to insure people with imports. Surely there's plenty of people who only use their cars as weekenders (if that!) yet we still have to pay the same. They do it for nana cars so why not ours..?
you will find that shannons does insure you on your circumstances....ie if your car is a weekender then your insurance premium isnt that high....but i think that means your not covered from monday - friday....so its a big risk you take....but if you only drive it on sat and sun then shouldnt be a problem.....
yeah we do have it set up like that with shannons.. a weekender and a daily.. we thought it'd reduce it but it really didn't.. the weekender car literally does no more than 5,000 kms a yr.. it should be based on how many kms you drive it as aposed to being a 'weekender' that gets done all day sat/sun .. if that makes sense!
Edited by sare
i cannot remember who the insurance company was that had their Ad on the tv.....in regards to pay as you go or something like that.....i didnt look much into it however but it might pay for you to look a bit into that Sarah :P
they dont cover imports im pretty sure.
plus, this:
Underwriting knockout
We are unable to offer you an online quote for the following underwriting reason(s):
We do not underwrite one or more of the modifications on your car.
One of the drivers of the insured car is under 25 years of age.
We apologise for any inconvenience this may cause you.
If you think you made a mistake on the previous page, please click the "back" button and correct your answers. Please remember your Duty of Disclosure, which is outlined on the top of the first page.
Said modifications include:
* AMG
* Active Suspension - Bounce
* Air Brushed &/or Chameleon Paint
* Blow Off Valve
* Bonnet Scoop(s)
* Drop Fuel Tanks
* External Fluorescent Lighting
* Flamer Kit installed
* Lowered Suspension - Non factory fitted
* Nitrous Oxide System - NOS
* Non Standard Body Kits
* Non Standard Boost Controller
* Non Standard Carburettor
* Non Standard Engine
* Non Standard Intercooler
* Non Standard Supercharger
* Non Standard Turbocharging
* Performance Cam Shaft
* Performance Cylinder Heads/Modifications
* Performance ECU Chip
* Performance Exhaust System
* Racing Harness
* Raised Suspension - more than 50mm
* Roll Cage
* Wheel Arch Flares
* Non Standard Cold Air Intake
http://www.payasyoudrive.com.au/
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
