Lol! My -9's didn't come with actuators, and I thought I could 'cheat'. Nope you gotta spend the $$$ lol.
Yeah, the nasty compliance cat won't be there for long, but I will still run a cat as I'm soft and don't want the hassles....
Okay. Got a tune done the other day.
Bad news is the stock actuators I put on the -9's can't control the wastegates properly so the boost is wavy lol, even boost controller couldn't keep it steady.
So new stronger adjustable one's are on order.
So good news is the car runs pretty well now and good response, mid range torque is great!
Boost peaked at 18PSI and 288RWKW @6500PRM to 8000.
10psi at 3300
15psi at 3700
18psi at 4000
16 at 4900
15.5 at 5300
16 at 6400 etc.
So that was with stock intake, stock fuel system, stock AFM's.
Non standard parts: boost controller, -9's, Power fc, intercooler, front pipe, and 3 inch cat back, and compliance cat.
interesting... im getting 270rwkw at 15psi
almost the same mods as yous... except no boost controller, cooler or front pipe
lol that boost curve is all over the shop
i've bought a metal racing cat which i will 'modify' for more flow and looking for a decent front pipe...
once those are in my boost should come on as early as yours
then to get some AFMs n injectors n put 20psi through it :D
hey probably noobish question here guys but will the actuators that came with my -5's be able to control boost properly once i get my pfc/injectors in and turn the boost up?
I'm only planning to run 18psi.....or so.
Under 20psi makes baby Jesus cry
Lol
What are your thoughts on them compared to the r32 setup now you've had them tuned etc and it's a more of less fair comparison until you build the motor and turn it up :D
Ha ha Steve-o, yeah 25PSI feels strong lolz!
This setup feels a lot more alive, especially in the twisties. Found that I could stay in a higher gear and not have to rev the guts out of it. It was hitting 18psi around 3600 or so in 3rd and 4th etc when I glimpsed at the display accelerating up slight hilly corners tonight. In a straight line though, it doesn't feel as aggressive as the 2530's on the 32, but the speedo says otherwise....
I liked the way the 2530's came onto boost and charged towards 8000rpm, but there wasn't much happening under 5000rpm, so the 34 with the -9's do work out well, and is just as fast as the 32 with less hp. I wanted more under the curve this time and considering the 34 is heavier, it worked out well. Ploding along in traffic is easy and I find I don't need much throttle to get going.
When one of my mates was driving back in his car after we picked up my car, he said that he could hear the tyres ripping into the road when I accelerated in 1st and 2nd gears, I just laughed as I thought it was funny, but it really has got a nice strong torque band.
Injectors are on 92% duty so there is a little left in them.
Better actuators are on order and a better cat converter. I'm sure this will make it a little better again, so I'm happy with the results.
Yes that's how I would expect these -9/GTSS turbos to work . The reason why they feel good is because they make good torque at lower revs so you don't have to chase high revs to get some pull .
Yes the 2530 and similar dryers make the numbers buts that's because the higher RPM numbers artificially raise the Hp/Kw number . Torque is the measure of turning force and more torque means more acceleration and yes the ability to pull higher gears from the lower mid range engine revs wise .
Eventually people tire of being impressed by high revs and want things that haul from lower revs , often just as fast but a LOT easier to drive and live with .
The feller in the post above I'm sure can understand what I mean when I say these turbos to a degree mimic a larger capacity engine which is what GTRs always needed . With stripped out tarmac racers no one cares what happens south of 4000 revs but when in road going guise that tonne and a half takes some moving when stopping and starting and slothing around in today's traffic levels .
I personally think anyone who wants a fast std capacity road weight GTR has rocks in their heads for not using these turbos . These are good road cars units , maybe not so good for drag or a real racer buy they are so far divorced from what makes a road car good as to be irrelevant .
Your opinions your calls , I don't like/have GTRs but if I had to have one they are what I'd use on the street .
A .
Awesome, cheers!
Whats better out of -7s and -9s or am I silly for asking this question? Looking at options for my street GTR (which sees a track every couple of months) and looks like everyone loves the -9s and thinks -5s are too laggy, I am very tempted to buy some new -5s cheap off a member here but don't want to regret it?
If I had the following basic mods:
full exhaust including 3" straight through cat, stock dumps
cam gears
power fc
apexi pods
What would you do and would you do more things at the same time to make it more worth while?
Leigh,
Go for -9s, you won't regret it, you're welcome to ride in my R before you decide if you want (that'd have to be next week as I'm moving houses tomorrow and rest of this weekend - late night may be a option).
Have you changed the clutch yet?
Done 100,000km service?
That's all I can think of for now.
Cheers
Grant
Ill be doing the 100k at the same time probably get a kit from Kudos or something, getting some quotes for -9s as well I think they would be best a lot of people think, as for clutch I'm not sure whats in it.. should I wait for it to go bang or what? lol
And yes I will take you up on that ride offer I think! coming to apple peel tomorrow night? if you can make it that would be sweet :D
hells yes Hamish :D its been a while since I've entered a deca and it will be the first time in a turbo charged vehicle so will be interesting to see how I can handle the extra power and if I can put it all down
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
