Ill be doing the 100k at the same time probably get a kit from Kudos or something, getting some quotes for -9s as well I think they would be best a lot of people think, as for clutch I'm not sure whats in it.. should I wait for it to go bang or what? lol
And yes I will take you up on that ride offer I think! coming to apple peel tomorrow night? if you can make it that would be sweet :D
Leigh,
I bought my OE Replacment 100k service kit, exhaust manifold gasket + stud kit from Kudos, defintely recommend them.
As for clutch, I'd replace them along with turbos - the less time the R spends in shop, more time you can giggle like girl every time it hits boost.
About Apple Peel meet, I may swing by seeing I'll be living close to the area.
Cheers
Grant
If the car is already in the shop and you can't do the clutch yourself get it done, but otherwise leave it until its stuffed and get your moneys worth out of it. It isn't that hard to change if you have 3 people, two to hold the gearbox and one to locate it. I managed it with just one other person and only axel stands, was a bit of a flamin mongrel trying to bench press the box in but we managed it in about 30 minutes.
Sounds good grant I will see you tonight then hopefully!
As for the clutch I suppose I'm better off doing it at the same time (don't want it to stuff up a drag day or anything) any recommendations or should I be going to the different section on the forum? :banana:
Leigh,
I've got OS Giken Triple plate in mine, I was recommended Nismo Coppermix Twin plate but I picked my OS Giken with pull to push converter kit for a price I couldn't refuse.
Hopefully I'll be able to pop in tonight as it's 5 mins drive from my new house.
Cheers
Grant
Only downside to R33 or R34 dumps, is it takes a 18mm O2 sensor thread VS the R32's 12mm O2 sensor thread.. can be tricky to get a bung that makes the sensor part protrude out far enough in the correct position (i've seen pictures of R33/R34 dumps with these bungs where the sensor just isn't far out enough into the exhaust gas flow to be effective)
  • 3 weeks later...
Finally got the -9s in my hot little hands along with the Garrett actuators. Before I install them will the actuators be up to the task of handling 300rwkw? How do they compare to the HKS ones and should I maybe just buy the HKS ones?
  • 2 months later...
Well I have just been able to exchange my -5's for a pair of -9's. Can someone confirm the part number is correct - 707160-5009S?
I remember my -5's just read 707160-5. I am assuming Garrett has chnaged the numbering system along the way.
does anyone know the reason why -9's do not come with actuators, only as a additional add on option? is it simply just a money grab being the more "popular choice"
Most Garretts like that have a part number with and without actuators. Some ppl want to save as much as possible by using stock actuators.
The 707160-9 is without
The 780371-1 is with
Other than that, it's the same turbo.
  • 1 month later...
Hey guys,
Just wondering if my understanding is coccerect here:
Garret -5's are very similar to hks 2530's? Which have most top end but least responsive?
Garret -9's are very similar to hks gt-ss? Unsure how they compare in terms of response and top end power?
Are garret -7's are similar to hks gt-rs? Least top end but most responsive?
If anyone could clarify this, it would be greatly appreciated...im bloody confused haha.
Hey guys,
i am no expert but it goes like this
-5 AKA HKS 2530 - Good top end and good response also in RB26 with build internals and head work / Stroked engine, but for normal RB26 with stock internals / street driven a bit laggy, "this laggyness is not always clearly shown in a Dyno apparently, but noticeable on the road" when compared others. lot of people with -5 street driven and loving it
-7 AKA Nissan R34 N1 - good response and good balance of power for Street driven GTR , but by no means a bragging rights turbo when it comes to numbers
-9 AKA GT-SS - best response and good power for street package, but will run out of puff in the top end, better and new technology than -7 and most recommended for street package with mostly stock internals
-10 AKA GT-RS - big power figures and not so recommended for street GTR without built engine.
I will be getting -9 end of the year, not really interested in any thing else, unless -7 comes up in the forums for really good price
Just my 2C
Also check out single turbo conversion side of the world, if your thinking of GT-RS level of turbos.....
all around, good choice we have in GTR world i think
:action-smiley-069:
Just my 2C
:action-smiley-069:
Cheers mate! That helps a lot.
Dash 5 similar but not the same as a HKS GT2530 , different turbine housing and compressor wheel .
I thought R34 GTR N1 turbos were a unique GT2556R and not an off the shelf GT2560R .
Dash 9 IS a GTSS and they are supplied to HKS without actuators so they can fit their own higher rate ones .
A .
read the dyno threads?
basically nothing below 5000-5500rpm on a 2.6-2.8lt, making 450rwkw+
and that's obviously taking into account the head work needed to support etc.
there is plenty of info in the pages here.
realistically unless you have a big budget 3lt+ motor or just pure drag race car 2.6-2.8lt, then they are a bad choice.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
