Are -10's the Garrett GT2871R Ball Bearing Turbos. You guys hav much info about the -10 in terms of when they come on boost, top end power etc? Do many gtrs hav this setup?
Cheers
Unless its on a 3L + I wouldnt go near them. I have RS's (pretty much -10's) on a 2.8 and they will be replaced with a set of -5's. Stupid choof choof turbo's
whats up with the last RB26 dyno post -5's @ 18psi and only 270rwkw ?? sure its pretty much a standard engine, but I had standard engine & standard turbos high flowed making exactly the same power at the same boost ??
theres quite a few others on there @18-19psi making around the 360rwkw mark ? doesn't look right
yeah stock turbos will make 270kw with some cam gear adjustment, 15psi and a good tune (my old car did and still does). still different cars get different results. no way to know what the tune is like, or the supporting mods etc or even how accurate the dyno is. at say 20psi I've seen -5s make between 300kw and 360kw. the mid point of around 330kw is about what they should make at that boost. anything more is gravy. :)
Wouldn't be surprised if they're -9's with a result like that
im glad i got -7's, they are so dam responsive, perfect for a quick street GTR...
my goal was to run around 280 - 300kw with the stock internals, but with sard fuel pump, nismo 600cc injectors, r34 gtr dumps/stainless front pipe/de-cat/3.5" cat back zorst, nistune, greddy cam gears, greddy profec b spec 2
so far only been road tuned on 18psi without cam gears dialed in, getting dyno tuned on the 12th of this month, hopinh for a solid number and a punchy mid range @ 20psi and gears dialed in
will post results in few weeks time :)
  • 4 months later...
read through this whole thread and -9 > -7 from what i can see, also would a gtx3582r with .82 rear be compairable response to a pair of -5's? obviously be light switch power with the 35 but i was wondering if they would come on in a similar rpm.
I know time and time again people say just to buy garrets, HKS isn't worth the mark up.
BUT
would a GT-SS set up have ANY benefit, no matter how small, over a -9 set up ??
Also from my understanding, HKS kit comes with everything you need to install and the -9s are turbos only, would the cost be more comparable after you buy the rest of the necessary items to fit the -9s ?
thanks for any replies :)
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
