Other thing is the turbos are REALLY laggy.
I get 18psi by 6000rpm and power drops off completely at 22psi at 7500rpm so theres no point revving past there...
Has it been tuned? If it has I'd be finding someone else to tune it.
I think this is your issue as well.
Is the engine healthy i.e. done a compression test as this could be the source as well? Your tuner should have diagnosed if there was an issue from the onset.
It can be low reading all it likes. 18 psi at 6000 rpm then falls over at 7500 is the issue.
This is the dyno chart. If you could interperet it that would be great.
Sorry its not in RPM. If it helps, I've got an RB25 box and 4.08 gears.
Edited by TheGeniusMoose
R33GTR motor. 155PSI compression on all 6
2860-5 turbos
255L walbro pump
Nismo 600CC injectors
RB25 box and 3.08 diff gears
Coppermix clutch
STD r33 GTR FMIC piping
Power FC D Jectro
Greddy Profec B
8psi actuators
Is that what you need to know?
What turbos are they?
What's the rest of the setup?
2860-5 turbos
255L walbro pump
Coppermix clutch
Power FC D Jectro
Greddy Profec B
8psi actuators
Also need exhaust details. You should have minimum 3.5in with metallic matrix cat. Take a look at the RB26 sticky to see what you should be getting - something is seriously wrong with your result. Injectors might run out of puff if they're not clean.
Twin 3" dumps into a 3.5 decat and 3" cat back
I'd have thought cam gears wind a bit more response in and not a whole heap of power. Regardless... something in my current setup is very wrong without buying new stuff I think.
Depends which way you turn the gears.
Here is a question for you rev heads.
My build comprises of the following:
Tomei Advance Spec RB26 (long engine) spec are here http://www.tomeipowered.com/BTE/index.php/2011/04/28/rb26-complete-engine-advanced-spec/
Garrett 2860R -5s (ex. housings lightly ported)
HKS actuators (set at 1 bar each)
OEM ex. Manifolds (ported)
Mines dump Pipes (Pipe diameter: 70φ)
Midori Ti front pipes (80φ diameter)
Catco Race Cat (3' diameter)
Tomei Ti Expreme cat back exhaust (3.5' diameter)
HKS fuel rail
HKS 1,000cc injectors
Tomei fuel pressure regulator
SARD Intank Fuel Pump (280ltr p/h) (in bold because I believe this will be a weak point)
Nismo Plenum
Cooling Pro I/C (100mm)
Apexi Power FC + HC
To be tuned on E85
Boost say 20psi
What power do you think I should make? and do you think that choice of -5s is appropriate?
Why have a 3 inch cat ? Make it the same size as your catback.
I thought that would be restriction....where can I get a 3.5in cat back from?
And why only 20 psi. IIRC, those Tomei engines are 8:5:1 (correct me if I'm wrong). 24 on pump fuel!
20psi was just an estimate
Advance spec is 8:4:1 (same as Tomei 2.8 Genesis) if that changes anything???
Edited by Ants
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
