I highly doubt it, or the Gibson 32 would have run a nice aftermarket 3.5 inch system instead of sidepipes.
Hehe :happy: The 34 with the same combo as mine minus cams made similar power and response too my old setup, 2 cars with near identical build, one witha side pipe and mine with a quiet 3inch exhaust! Both running same boost etc initially!
we are not talking about group A race cars mate but street cars, with standard (or very close to standard) capacity 26's with low mounts
and if you were to read correctly, at no point did I mention that the bigger the exhaust the less power - in fact I pretty much said the opposite.
That’s about 60% of the story. The other 40% is why carry around the weight of a full exhaust and mufflers. Why take up space around rear suspension and shafts where you want to run fuel cells and diff/trans coolers.
Why run the risk of a muffler collapsing and hurting power? So introduces need to life components and expense associated with it.
But generally I agree…because ultimately if running side pipes vs full length exhaust hurt power then they would have found a work around. Ultimately the gases before the turbos and immediately after then leave the turbing housing is where most of the battle is fought
Secondly if you are rebuilding your engine put performance cams in it and run -5s. Best all round setup for response and HP in a 26.
Everyone had previously recommended not to go with -5s on a 2.6.. Why do you recommend otherwise?
Have you driven or been in a built, cammed 26 with -5s pushing around 400kws?
Define "performance cams"?
What ever the engine builder recommends for his build. I leave that to the RB masters. As long as the car does what I want it to do, the engine builder can put whatever Cam he wants. All I know is that with standard cams people say it's laggy, but personally I don't mind lag. He he he.
WAITING for aggressive boost is half the fun.
Each to their own, but I couldn't think of anything worse... Waiting for your engine to make some meaningful grunt while a better setup package blasts into the sunset!
I totally agree with you, the rush of boost is awesome!
Although, I sold my GTRS's as full boost was about 5.5krpm which was great for drag racing but not for street.
Having full boost @ 4krpm with -5s and poncams is my next setup...should be achievable :)
If your car is for street use...
-5's make its power towards the top end.
-5's on a stock RB26 would not be as responsive as a set of -7's / -9's.
Hence why people upgrade the cams for better lowdown (2.6lt).
Or people go with a 2.6lt HKS V-Cam / 2.8lt HKS V-Cam or RB28 Stroker.
And since your engine is getting a rebuild it opens you up to all the options.
I personally prefer a responsive RB26 hence why you choosing -9's is a good choice.
Change gears
That won't work in all situations.
You're coming out of a second gear corner at 4000 rpm with a Horrible setup like RS's on a 2.6. You can't tell me you're gonna go back to first!
So you plant your foot and choo choo all the way up the hill, while your mate with -9's blasts past you like you're standing still.
Anyway we are getting into the old forum fight of the definition of laggy setup. Each to their own on this one. I think the best advice is experiencing different setups to see what your happy with. Me personally love the built, cammed, -5 RB26 Setup. Best of both worlds and as my engine builder said, 'the 26s sweet spot'. I drive it daily and love that it's off boost in traffic and starts coming on at a higher rev range. I would hate boost coming on too early. BUT when I want to drive the car then I hold it between 4 and 7-8 and she is a rocket and no lag when it matters. My other car is a HSV LS2 with old school lumpiness and a hi stall. Again in traffic she purrs under stall with low torque to the wheels but when asked to she will flash to 4k and all hell will break loose. Best of both world with both Setups in my opinion.
Change gears
We are talking about -5s on a built and cammed 26 not rs's that won't be at their peak at 4k.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
