right guys i have most my stuff now here is a list
hks 3037 pro s
hks hi mount
power fc with boost control
tomie timing gears
660cc injector
billet fuel rail
greddy copy intake
Q45 throttle body
braded turbo lines
greddy intercooler
tail 38mm wastegate
nismo timing belt
z32 afm
fuel reg
anyway im think i should do copper head gasket before fitting all up so its done as im going for 280-300 rwkw on stock motor as im unsure if stock head gasket will hold up to it as boost will be up around 20psi
Edited by mattsr31
How long is a piece of string.
All depends on tune, health of engine ect ect.
People have run up to 300rwkw with no problem. If you want to get serious about more power then budget for a rebuild incase the sh1t hits the fan.
IBTL
If it's copper the don't seal water that well, great for compression but crap for water, what most people use is steel multi layer head gaskets copper are real old school. standard gaskets in rb30's have been used to 450rwkw+, most people only change from stock because they have the engine apart and why skimp out on a head gasket
so there is no need to worry about it till i need the head off is that what ur saying mate
3 studs in the exhaust side broke when taking manifold off as long as i can get a drill in there i wont need to remove head
what studs are best for replacement of old stock ones
many people run standard i mean nissan head gaskets with no problem with massive boost and swear by them, I run a cometic steel head gasket and would recommend using one but don't wory about it until it's apart or till the gassket blows (highly unlikely unless there is a problem) I would use stock studs but arp might make something?
I wasnt and arnt after 280kw (250kw eventually will be nice) but i still went along in my project (3.5yrs of ownership/modding) for some recent head work
bought tomei cams & springs last june ($ to $ was good back then) and metal head gasget (Cometic brand). also ARP head bolts, and ported head work etc
ready for a GT3076 or a turbo such as yours all in good time, but got a highflow Slide turbo atm.
without catconverter was dyno'd at 226kw with mail-order ecu chip tune & safc/sitc.
IF you are going to pull the head down as part of your project then yeah budget it in, metal headgasket and some touchup of the ports etc.
depends on your mindset I guess........
your stock motor wont last long at 280 -300kw regardless of your tune start saving for rebuild
Obviouisly your wealth of experience speaking here, many people have run over 330rwkw for extended periods. Its all in the components being used, and the quality of the fuel/tune.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
