Hey guys,
quick question . i have CE28's on my 34GT-T.. and they have a +45 offset on the rears... is that really bad? cause i've been looking around the forums and most of you guys only have +12 or so. So im not sure if my offset is bad or not? I have 265/40 (It could be 35.. not sure haha) R18 Direzza's if that will help..
Thanks Jin
https://www.sau.com.au/forums/topic/254686-confused-with-my-rims/
If they are clearing all suspension bars and rods & dont scrub the guards when cornering hard then its fine.
Hard to work out whats the ideal offset for a car when you go to buy rims, I got a R32Gtst & put drifteks on it. Rears are +36 offset and clears all the above but they stick out about 5mm past the outer edge of the rear guards- defect waiting to happen LOL- was assured they were legal when I bought them- but meh looks phat so they stay
Hey guys,
Thanks Jin
stock offset for gt-t on the rear is +38 and front is +35,
so you shouldn't have an issue with +45
Isn't that greater than stock? If so, yes.
I'm pretty sure that's on GT-Rs only, unless these GT-t owners have really thin wheels.
luke enr34 runs 18x10 +18 i think on just rolled guards, i ran 17x9 +16's on mine for a while, now i run 17x9 -1's on small flares.
u just have to know what ur doing to make them fit.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
