When: Saturday 21 February
Where: Kamikaze Motors
21 Walkers Road, Nunawading
Time: 10am - till we run out of cars
Cost: $40 for 3 runs and a printout - the dyno is 4WD
Membership Bonuses:
Renewing members - $40 for 12 months
New members - $50 for 12 months
All existing members are encouraged to come along and renew their memberships at the low price of just $40. Even if your membership doesn't expire until June or September, you can still come along on the day and pay $40 and we will update your membership for a further 12 months from your expiry date.
There will be a free BBQ for all current SAU Vic members, and a gold coin donation for anyone else wanting some food or drinks. Please post in the thread if you are planning on coming so we get an idea of numbers for catering.
Also - if you are not aware, the Committee has produced a 2009 Wall Calendar and all current members are entitled to a FREE copy. Come along to the Dyno Day at Kamikaze to collect yours.
So come down, chuck your car on the dyno, have a snag, check out Kamikaze's fantastic showroom and renew/sign-up to SAU Victoria.
Hope to see you all there.
  • Replies 140
Sounds good! Will try and pop down; work permitting.
Question: My membership card says it expires on the 1/2/9. We have a member cruise on the 8/2/9, do i pay my $40 to a committee member on the 8/2/9 or do i hold off till the 21st? Just asking as my membership officially expires before the "renewal" day and a few others will be in the same predicament.
Its being discussed over email at the moment.
Once everyone is agreeance on how the club rules are going to be interpreted, there will be a response to it :)
As it stands, most people are like you, expiring 01/02/09
So just be patient.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
