i got afc analog one with the knob would that affect anything and i never noticed it before as it never ever did it i notice it in the passenger side mirror are you guys sure this is safe.
also really dumb question how do you guys put those movies and pics under your user name
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-543066
The one knob AFCs are essentially useless. I'd say I'm almost 99% sure that's what is making you run rich and causing the smoke. They only allow you to add/remove fuel across the entire rev range, so you cannot fine tune it. So if you are adding 5% fuel at 5000rpm (just as an example), you are also adding that at 1000rpm. Not efficient at all. To be honest, I have no idea why Apexi made it.
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-543528
I got greyish smoke too :P
A couple months ago the engine made tapping noise which sounds very very similar to my old Mitsubishi Galant with valve stem seal problem :( unlike my old Mitsu where noise is still there all the way, in my skyline the noise is gone when engine is warm
But after detonation problem on a recent cruise, the cold start tapping noise is gone and hasn't come back since.... wtf????
Must be something else...
turbo seal on its way out?
is that tapping noise = turbo wheel touching its housing?
that detonation (due to over boost to 15psi) could have chipped the wheel edges so it no longer touch the housing?
I'm sure exhaust wheel still there, car can still make that much boost over 10psi (but I've turned it down to 8psi since)
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-543543
Originally posted by rs73
I got greyish smoke too :(
A couple months ago the engine made tapping noise which sounds very very similar to my old Mitsubishi Galant with valve stem seal problem :D unlike my old Mitsu where noise is still there all the way, in my skyline the noise is gone when engine is warm
If the turbo wheel was touching the housing it would whale/howl not tap.
I would actually see a mechanic and do a compression test, amounst other checks.
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-544637
hehehehe , try this go downhill a very long and steep hill stay in 4th or third gear do not touch the accelerator untill u get to the bottom when u get to the bottom of the hill eccelerate look in the mirror for smoke if u see blue smoke its u r valve stem seals . if it blows blue smoke under hard ecceleration and or high revs then its piston rings . just black smoke running a little rich but u'll get more at high rpm if running rich .
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-544711
Al,
My turbo squeal like a mad pig on cold.... is that normal?
When warm it doesn't....
Anyway my car is now in the "hospital" now... hopefully
nothing serious...
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-545055
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
