  • Replies 47
Posted Images
Could be anything really.
I would assume the red light is for your alarm when you arm it it blinks to tell you its on...
The siliver flick switch, Im guessing a RWD/AWD or 4WD switch..? Could be some activation switch for flog lights...
Can you pull down the compartment lid that its stored in and trace the wires and connections..?
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409863
try it and see?
maybe it's a simpsons style switch for 'MERRY CHRISTMAS 1984' on your roof?
Lol I tried it and it doesn't actually seem to do much when the car is stationary. Not really game enough to fiddle with it during driving, in case it kills power or locks the steering or something bizarre.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409864
Lol flog lights. The compartment lid is for the moneybox... can't see wires in it. I checked and you're right about the red light.
It would be awesome if I had a 2WD/AWD switch there without knowing it.... Wax On, Wax Off, Drift On, Drift Off.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409875
Doh! FOG lights I mean. LOL!
Maybe switch on the car and let it idle, then flick the silver switch and see if any lights pop up in the dash / cluster were your speedo and tachos are... Also hear out for any noises when the swtich is flicked...
Or take it hard around a corner then pull over, let it idle for a minute or 2, then flick the switch and take it hard around the same corner to see if it makes any difference...
My friend Tim GTR on SAU has a R33 GTR with a flick swtich and its for the 2WD/AWD switch and when you activate it, there is a a quick "Humming" or a very low tone "Beep" "Beep" noise.
But thats just his car.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409905
No sounds or icons light up when idling and flicking back on forth with the switch. I might try the cornering thing when it's raining, just to make sure :)
So I guess the other R34 GTR owners don't have this switch? Maybe it's just a dummy switch installed for looks lol.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409938
Could be a "Cheat" switch LOL!
Friend imported a R32 GTR and had this switch and when you flick it, it activates the brake lights, so when ppl are street or circut racing you and see you brake light flickering, they slow down, but you still keep going LMAO!
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409950
My Money is on Neons :)
ROFL.
Wow, that is such a dastardly evil invention! Would be great for those tailgating douchebags as well. I checked though - unfortunately it's not.
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4409971
I wouldnt think it would be to turn off the immobiliser/disable... that would be a bit pointless having it in full view
It wont be a 4WD/RWD switch, you cant run a 34 in RWD without taking out the drive shaft (or you'll kill the transfer case)...
Stick your beaver under one or other side of the car and see if you can see something... cause im thinking neons too :happy:
https://www.sau.com.au/forums/topic/255712-mystery-switch/#findComment-4410105
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
