I am looking at the Mines & Reimax cam cover baffles for the RB26's. The thing I can quite get my head around is physically how large are they? Does anyone have some approx dimension - particularly for the Mines ones. The Reimax equivalents appear to be much shorter.
Both are shown on the Greenline site if anyone is wondering where to look.
https://www.sau.com.au/forums/topic/256610-cam-cover-baffles/
ive fitted 5 sets of these...the most recent on Sunday. The Mines ones are longer and need to be drilled to clear the cam cap studs if you keep the baffle caps on.
I never drilled mine !
Did you move the baffle caps to the new position as shown in the instructions ?
cheers cokey
cheers cokey
do you have camp cap studs? or just the std bolts?
i think paul was referring to the aftermarket studs having to be clearanced
Just the std setup which are bolts for all but the 8 which hold the baffle caps they are studs.
Maybe Paul could post a pic of the drilling ?
When he has a minute,as he is busy preparing for new arrival.
Best wishes to stace.
cokey
cokey
yeah the ones ive installed all used cam cap studs...not bolts...so needed drilling.
new arrival?
Edited by DiRTgarage
  • 3 weeks later...
Anyone able to give a quick run-down of how to install these puppies? I picked up a set this week but came with no instructions (I know there are ones posted above, however I don't read Japanese) Is it a simple straight swap affair or do some modifications need to be performed?
  • 1 month later...
I'm wondering, would it be overkill to use both the Mines triple flow baffle plates, and a oil/air seperator at the same time?
I'm also wondering with the Mine's plates, oil purists here (not one myself, but hypothetically anyway); wouldn't you want the blowby oil that would normally come out the stock baffle plate to be caught by your oil catch can than a oil/air seperator or the triple flow baffle plates sending it back into the sump?
Check attachment if still needed the instructions
Installation_Instructions_for_Triple_Flow_Cam_Cover_Baffle_Plate.pdf
  • Like 1
Take em out , blank the breathers off and use a GZ vacuum pump , helps seal the rings better - reduces blow by -reduced and relieves crank case pressure - allows oil to drain out of the head quicker at higher rpm and increases hp - up to 50hp in some cases.Also helps keep oil cleaner if running a little rich in some areas. Good bank for buck.
do you plumb the pump into the back welsh plug where you typically plumb the head drain into?
what kind of vacuum figure would you aim for in the crankcase?
  • 5 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
